Moisture meter
Discussion in 'The Wood Pile' started by Tony2Truck, Sep 14, 2014.
  1. Tony2Truck
    Tony2Truck
    Have seen a lot of you guys talk about your MM reading. Was wondering was meter you guys use. Looking to purchase one soon. Thanks everyone in advance.
  2. dylskee
    dylskee
    Central MA
  3. Grizzly Adam
    Grizzly Adam Guest
    El cheapo from Menards. Tool something is the brand...
  4. Well Seasoned
    splitoak likes this.
  5. schlot
    schlot
    NW Iowa
    Same as dylskee...works fine for me.
  6. Grizzly Adam
    Grizzly Adam Guest
    Well Seasoned likes this.
  7. Well Seasoned
    Hmmm, I guess the brand is "el-cheapo" :)
    splitoak and Grizzly Adam like this.
  8. UncleJoe
    UncleJoe
    SC Pa
    Mine is a "General" I got from Lowe's for $20.
  9. swags
    swags Moderator
    +1 here, same one
    Dennis said something a few years ago that was a little foreign to me at the time but is how it is now for me. The best moisture meter is a three year calendar. That's very true, since I'm a few years ahead now I don't even break out the meter, occasionally I'll get curious and check it out. But of you aren't in that position a moisture meter is a cheap and useful tool.
  10. Sinngetreu
    Sinngetreu
    North Central Iowa
    General here too. Although the water droplets on the top left is a bit misleading. Other than that, I like it!
  11. Certified106
    Certified106
    In The Hills
    I also have the general and it has worked fine. I hadn't used it in 2-3 years but actually used this afternoon to check some really old red oak I was cutting up.
    Shawn Curry and HDRock like this.
  12. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    Swags is right. Hardly ever use one now. But it's still good for checking cold air infiltration to the house. Mine is a cheap Harbor Freight.
  13. trooper
    trooper
    Arizona: It's a Dry Heat!
    I use the General also. The other test is to smack 2 pieces together. You should a crack similar to a baseball hitting a bat. That be dry 'nuff.
  14. Tony2Truck
    Tony2Truck
    My problem is I've had wood stored along side of my garage but there's a 6 ft privacy fence 4 ft away. So my wood doesn't get a lot of sun or wind through it. This years wood is a mix of ash that's 3 years old along with 3 year old maple. Just wanted to give it a double check. And I really don't have a place to move it to to get more sun and wind at home. I could move it to a friends shop that is about 15 minutes away but he's not there much and I'm afraid it would grow legs and walk away.
  15. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    This cheapo from ebay, gives the same readings at my Fathers more expensive unit
    $8.49 with Free Shipping
    Drvn4wood likes this.
  16. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    Anyone else have problems with the prongs bending on the general? It seems to work well though I suppose.
  17. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    I might buy one of those. Mine seems about ready to break.
  18. boxygen
    boxygen
    I wouldnt bother testing anything that has been split and stacked 3 years. Just burn it! :whistle:
    Tony2Truck likes this.
  19. tfdchief
    tfdchief
    Tuscola, IL
    I have 2 different ones......mostly gadgets.....I find the most reliable moisture meter is mother nature.....3 years of seasoning.:)
