Which way to face new stove location installation?
Discussion in 'Modern EPA Stoves and Fireplaces' started by wildwest, Sep 8, 2023.
  1. wildwest
    Thanks guys, it is what it is. We were like a well tuned force before I got sick and did some pretty impressive things together over the years. Now it's pretty much him on his own and kid and I "help" :confused:. It's mostly time and no other pair of muscles to make it happen like it used to. Kiddo is is getting bigger and really pitching in :) We're functional in this home, not pretty but functional and that's what counts. Turns out us 3 are a good painting team. He rolls, I trim floor, and kiddo trims the ceiling :)
  2. wildwest
    Thanks, I'm sold on since since Backwoods Savage told me :) I'm thinking two of the fans below. One to blow our room air into the alcove (floor air is cool), and another on the other kitty corner blowing straight up from floor towards ceiling to circulate air up there too. The room is ~25x20, kitchen/living room and heating all in one area. I have to wait til their delivered though, I'm really quite curious!!
  3. wildwest
  4. Canadian border VT
    Do you need a pic of my pumpkin orange master bathroom tub ??
  5. wildwest
    lol, your tub might be orange, I'm still waiting on flooring over the subfloor and a sink in my bathroom :rofl: :lol: I don't mind, toilet works and the shortie tub with lower walls is easier for me to get in and out of.
  6. Backwoods Savage
    wildwest and brenndatomu like this.
  7. wildwest
    I bought a couple knock off Honeywells, they work fine but now I'm spoiled with how quiet Vornados are.
  8. Backwoods Savage
    Yeah, I hate noisy fans.
    theburtman and wildwest like this.
  9. wildwest
    Farm out, reloaded the stove. I'm at 1 O'clock and cat is crusing along at med/high.
  10. wildwest
    Glass airwash? Glass is dirty on both bottom corners. And now the soot looks like someone threw glitter on it. Our wood is loosely cut to about the depth of the stove. We had an incredible mud storm last winter. Yes, mud. Literally chunks of silt mud from the bottom of an emptied lake, husband pressure washed windows, trucks, 5th wheel etc. It also deposited 3" layer of lake mud on our wood pile. We banged the mud off but there's still some on the nooks and crannies, is this whats causing the glitter?
    theburtman likes this.
  11. moresnow
    moresnow
    Mud storm:hair: That there is a term I've never heard. Until today.... Interesting!
    The lower corners of your glass will almost always be black. Nature of the BK beast. Nothing wrong.
    Glitter appearance is beyond me! Doubt its any bother.
    When turning down the stove. at what location are you extinguishing active flame?
    Running your low setting point just barely lower than having active flame will give you the "hottest" long term burn. This setting will give you occasional lazy flame that appears briefly and then disappears.
    Naturally running a setting with active flame will not give you the lengthy burn time that the stove is designed for.
    Note: any adjustment point will need to be left alone for 30 minutes to get an accurate result.
    Sounds like your getting some operation procedures figured out.
    Actively functioning cat at the 1'o clock position is impressive. Mostly at your altitude. Hmmmm
  12. brenndatomu
    I've seen that before...the glass gets black and then when you have a hot fire it dries the creosote out and sometimes it looks a little "glittery" like that
  13. wildwest
    Same, I hope to never see one again, and it was lake bottom silt mud. 3" on our entire property that dried like cement. Huge clean up, couldn't see out of any of the windows til husband borrowed a pressure washer from work.
    moresnow and brenndatomu like this.
  14. moresnow
    moresnow
    Post some mud storm pics if you took them.
    Hows the stove working?
  15. wildwest
    Creosote o_O I can't imagine it's my wood, it was deliverd split in 2021, he said he cut it 2020, lodgepole pine.
    I didn't take pics of the mud storm, wish I would have. Stove is running well as expected, we go 6-8 hours between reloads, that's a big deal for us! Except I've had to supplement with the pellet stove a few nights I was up late now that were around and under 10*, otherwise we use both in the morning to warm the house back up. I took the vornado fan from bedroom and that's helping a bit.
    theburtman, Chvymn99 and brenndatomu like this.
  16. brenndatomu
    No big deal...creosote is just unburnt wood gas that has mixed with the moisture in the wood (your wood is not 0%, is it?) and condensed on the glass...it happens...it'd be hard to not have at least a little in the corners of the glass...and if running a cat stove "low n slow", probably more than a little...
    theburtman, wildwest and Chvymn99 like this.
  17. wildwest
    Thank you, and yes, low and slow most of the day. I've never had glass before except the pellet stove.
    brenndatomu likes this.
  18. moresnow
    moresnow
    6-8 hrs between reloads seems like a really short reloading schedule? For a king. Huh.
    Full firebox reloads or partial?
    Possibly very, very dry softwoods!
    Good luck!
  19. wildwest
    Check mark on very dry softwoods, it doesn't coal like what I've seen here like hardwoods, literally burns down to a puff of 100% ash which means lighting the stove again. So we've been refilling while there's some glowing red wood left, ~ an inch or two where they land . For real though, 8 hours is GREAT to us, we could test it to see how long we could go but it's been burning 24/7 since we started 8 days ago. I think our splits might be a bit big, they're awesome for feeding giant smoke dragons but I cannot pack the stove tightly like I've seen here at FHC. Thanks a bunch for your input and help!
    What kind of pine do you burn?
    Chvymn99, theburtman and moresnow like this.
  20. brenndatomu
    Just split some of them...then keep those just to fill in the gaps when packing the stove...
    Chvymn99, theburtman and wildwest like this.
