Dock building
Discussion in 'The DIY Room' started by basod, Nov 20, 2023.
  1. basod
    basod
    Mount Cheaha AL
    Hey everyone… yes I’m still alive :D
    so project coming up building a “relatively inexpensive” dock/pier on my lake recreational lot.
    I’m thinking this will be a 16x12 with 4’ walkway. I’m planning on making a water jet to sink the posts as deep as I can hopefully 4’ minimum.
    I’ve built docks on land and put them in/out each season but this lake doesn’t freeze maybe floods occasionally.
    Having extensive knowledge of framing and decking what should I do?
    round posts vs. square?
    Build the main frame then the walkway?
    Bracing?
    Chaz, Screwloose, Horkn and 8 others like this.
  2. basod
    basod
    Mount Cheaha AL
  3. wildwest
    :drool:
    Chaz, Screwloose, metalcuttr and 2 others like this.
  4. Eric VW
    Glad you could still navigate to the site!
    :D
    Beautiful view!!!:thumbs:
    I’ll wait for some replies before I offer any guesses. :yes:
    Chaz, Screwloose, metalcuttr and 4 others like this.
  5. basod
    basod
    Mount Cheaha AL
    My initial research says round posts as there is no heartwood exposed to rot. Question becomes can I get lengths long enough at economical prices without being too big to handle.
    The winter pool lake level is down 2.5’ currently and I may be working in 3.5-4’ of water when setting the outer posts.
    Might be some squaring issues as they are irregular.
  6. Horkn
    How about a floating pier? Use the plastic floats.
    I made one a number of years ago. It was really simple
    You use steel poles to auger into the lake bottom and use a bracket to allow the dock to move vertically.
  7. basod
    basod
    Mount Cheaha AL
    Reviving my thread finally made some progress with my long holiday weekend.
    2x8x16’ joists under 20”oc with 2x6 decking.
    I’ve been building the box frames on the ground and using temporary support feet then sinking the posts- although the outer right side is being stubborn. IMG_5705.jpeg
    Chaz, Screwloose, metalcuttr and 10 others like this.
  8. basod
    basod
    Mount Cheaha AL
    Forgive the double picture post.
    Turns out the permit required 15’ setbacks from both sides. So I was granted a 5’ wide x 40’ long finger dock, apparently the previous owner of the adjacent lot took the liberty to add on to his similarly permitted dock and added a 20x16’ tee. The permit guy told me that there wasn’t much he could do about it, as it becomes grandfathered.
    Chaz, Screwloose, Horkn and 3 others like this.
  9. RCBS
    Needing a permit for a dock is so strange to me. Perhaps because of the posts. We don't use em here. Everything floats. Blue barrels are sometimes a commodity.
    Chaz, Screwloose, metalcuttr and 5 others like this.
  10. Canadian border VT
    Agree with RCBS I have no expertise in water that doesn’t freeze; some docks that are too large to pull seasonally get air bubblers placed by posts
    Chaz, Screwloose, basod and 4 others like this.
  11. Scotty Overkill
    Looking good so far, how have you been buddy?
    Chaz, Screwloose, basod and 3 others like this.
  12. Horkn
    Exactly.
    Chaz, Screwloose, eatonpcat and 2 others like this.
  13. basod
    basod
    Mount Cheaha AL
    It’s because the power company owns the lake- hydro dams up and down the Coosa River.
    Chaz, Screwloose, brenndatomu and 2 others like this.
  14. basod
    basod
    Mount Cheaha AL
    Laid about 16’ of deck boards this morning and used my pressure washer to sink the posts so much easier and faster. I’ll put the last 8’ section on afternoon this week then it’ll just be deck boards.
    Chaz, Screwloose, brenndatomu and 7 others like this.
  15. basod
    basod
    Mount Cheaha AL
    Doing well bud. Work has been busy took another promotion, sometimes it’s just more headaches :mad:
    Chaz, Screwloose, brenndatomu and 4 others like this.
  16. basod
    basod
    Mount Cheaha AL
    Finished up this weekend despite the weather. Started on the 5th pouring the small pad and then went shopping for a trash pump lumber and bits and pieces. Had heat index over 105 and blazing sun when I started to this past weekend with thunderstorms stopping work. Total just over $1600 including purchase of trash pump and suction hose from HF which was $360. I’m probably going to add cross braces to the legs when at winter pool and maybe some mobile home anchors with SS cable to prevent uplift in the event of a flood. I was able to get most of the posts 3.5’-4 down slightly tapered fat end down and filled around them with bags of pea stone hind sight probably should’ve used concrete.
    IMG_5700.jpeg IMG_5702.jpeg IMG_5706.jpeg IMG_5715.jpeg IMG_5721.jpeg IMG_5724.jpeg
    RCBS, Horkn, Chaz and 8 others like this.
  17. Eric VW
    Awesome work basod :yes:
    :handshake:
    What’s your current water depth at the end of the dock?
    Horkn, basod, Chaz and 4 others like this.
  18. brenndatomu
    So how does that work exactly? You blast until you think its deep enough and then send it, crossing all fingers and toes that it actually goes clear in?
    Horkn, basod, Chaz and 5 others like this.
  19. Eric VW
    I don’t know what the answer will be here, but have watched “jet pump” piling installs for docks. Pretty neat. Could do some simple measuring of initial water depth and translate that plus desired pile depth to the post in hand. IIRC, the “jet” (pipe, really) and post are pushed down into the lake bed at the same time… it’s been a while but I believe that’s how it was done the many teens-of-years ago when I witnessed the process.
    Horkn, Chaz, metalcuttr and 3 others like this.
  20. brenndatomu
    I kinda wondered if maybe that was the case...so it sounds like the post would end up being kinda sorta exactly in a precise-ish spot...
