Squarejig
Discussion in 'Chainsaws and Power Equipment' started by Eric Wanderweg, Nov 15, 2023.
  1. Eric Wanderweg
    Has anyone seen (or even better, used) one of these jigs to do square grind on their chain grinder? I’m a novice when it comes to square filing and it’s been proven to me time and time again that whenever I invest the time to do it, I rock my chain pretty hard after the fact :hair: I much prefer the performance of a square ground chain to round, so this seems like a good solution. I can’t justify buying one of these jigs, but being a toolmaker by trade I can make one. I already made the 45 degree angle piece. Before I make the rest of the components I’m looking for opinions. Thanks FHC crew.
    SQUAREJIG.LLC
  2. The Wood Wolverine
  3. The Wood Wolverine
    I still haven’t heard or seen anyone using this. After discovery, it just kinda fizzled away.
  4. Eric Wanderweg
  5. Eric Wanderweg
    The chain I rocked yesterday needed a ton of work, and it was already worked pretty well from converting it to square file from round. I ended up going buck wild with a Dremel to clear out the gullets. By the time I got the carnage on the top plates to disappear, they were considerably shorter. I figure this could be a good chain to experiment with.
  6. The Wood Wolverine
    huskihl Kevin, have you heard or seen anyone using it?
  7. The Wood Wolverine
    If you would want a chain ground on my Simington to have, just say the word and I’ll get you one. That might ease the curve getting your wheel profiled.
  8. Eric Wanderweg
    Thanks, much appreciated. I may take you up on that offer... There are quite a few online videos on how to use these jigs, and I'm no stranger to form grinding, but this is a little intimidating.
  9. huskihl
    huskihl
    Dude on AS was building it and looking for feedback a year ago. Seemed honest and open to ideas/perspectives. A couple guys on our fb sharpening group use them. Limited angle adjustments and manual wheel dressing, but it’ll make a square chain with a round grinder with some practice
  10. Eric Wanderweg
    Thanks for the input. I think once the wheel geometry is dialed in, the way to go would to be turn a wheel in the lathe and send it out for borazon coating. Either that or make some kind of norbide stick wedge-shaped dressing contraption for standard grinding wheels.
  11. Eric Wanderweg
    Merry Christmas to me :whistle:
    Seeing it firsthand I’m glad I didn’t spend too much time trying to reverse engineer it from internet pictures. There’s an added angle (about 5 degrees) that I would’ve completely missed had I continued on. I’ll give an update once I get into it and become successful at grinding square chain.
  12. The Wood Wolverine
    I was going to ask you about this a couple days ago. The YT vid showed up on my suggested the other day and remembered you were talking about building one. Keep us posted. :yes:
  13. T.Jeff Veal
    I would like one, but our Super Jolly grinder has the hydraulic clamp...
    Screwloose, metalcuttr, Mrxlh and 2 others like this.
  14. Khntr85
    Khntr85
    Did anyone ever get one of these I got one and it definitely works good
  15. Khntr85
    Khntr85
  16. Khntr85
    Khntr85
    I cut hardwood so I started with a “durable” grind….there is plenty of room for a more aggressive grind if I need….i wan this chain in my 362 and it cut great!!
  17. Khntr85
    Khntr85
    Also I put the jig on an Oregon 520 and it works great!!
  18. Khntr85
    Khntr85
    How you liking that jug, have you used it much yet??
    brenndatomu, eatonpcat and Screwloose like this.
  19. Eric Wanderweg
    So far so good. I've sharpened probably 2 dozen chains with it over the past year. No regrets.
  20. Khntr85
    Khntr85
    That’s great!!!
    First off what grinder do you have it on??!
    Mines on an Oregon 520….
    What angles you using I started with my base slide at 2, but I have don’t the last chain at 5, it was more aggressive…
    I do -10 for right cutters and +10 for left cutters the top plate adjustment….
    I haven’t tried the tilt yet!!!
    brenndatomu and eatonpcat like this.
