Suggestions for Temporary Enclosure of Porch
Discussion in 'The DIY Room' started by bogieb, Oct 21, 2023.
  1. wildwest
    Nice!! Personally I'm thrilled you have sunlight and a wind barrier/deterrent :)
    metalcuttr, MikeInMa, Chaz and 2 others like this.
  2. Woodpusherpro
    Woodpusherpro
    East of Dallas, Texas
    Temporary? Trampoline tarp cut to fit, with 1x2 to keep it in place. Wrap the ends in the 1x2 to keep it drom ripping or pulling. Works surprisingly well.
    Edit: I see the project is done, good job.
    wildwest, bogieb and MikeInMa like this.
  3. bogieb
    After yesterday's 4-5" of snow, followed by graupel and rain, I can report this was a successful endeavor. I do have a couple of places to improve next year, but all-in-all, I am pleased with the results. Pictures taken at 8am
    Inside of porch is nice and dry
    Close up of places they snow sliding off the roof hit the plastic before falling to the ground
    This is what the steps look like that don't have the plastic strips. The stuff coming off the roof falls on the railing and portions of it bounces back onto the steps. All of the steps are wet nearly all the way back to the house.
    Next year there will be adjustments made to account for that railing. I was pretty sure that is what would happen and it still ticks me off that the construction crew did not follow my direction to pull the support (and thus the entire porch and stairs) back from the edge of the roof by 6" to prevent this from happening. On the other hand, I will not be shoveling 35' worth of ramp this winter, and I'll be able to snow blow that entire section from the bottom of the stairs to the end of the house. So it's still a huge improvement over the last 10 winters.
  4. MikeInMa
  5. Woodwidow
    that is so great that it is working out for you. (Shudders and shivers) - snow already. We have not had a snowfall yet just some frosty mornings.
    metalcuttr, eatonpcat, Stinny and 4 others like this.
  6. Well Seasoned
    I did this to thanks to Canadian border VT nice setup! Enclosed half the deck that has the roof, less shoveling and no more storing the deck furniture and will retain heat from the gas fire pit. Win win
  7. Well Seasoned
    Excellent!
  8. bogieb
    We need pics :)
  9. Well Seasoned
    Closed in, used 2 panels as doors that slide up and outta the way until bad weather moves in.
  10. Canadian border VT
    Well Seasoned looks awesome.. you didn’t say next few weeks I have 3 left over panels somewhere :headbang:
  11. Well Seasoned
    That's OK, I was mostly closed in (I think) when I saw you. I just needed to figure out a quick door system. What I came up with will serve its purpose and maybe next year I'll frame a door. The deck heaves but the porch roof doesn't so needed to put something together that would work between the two. I'll number everything before I take it down in the spring which will make easy set back up next fall.
  12. bogieb
    Looks great and I'll bet it is nice and cozy in there when the fire is lit. Firewood doesn't get snow blown on it and not having to move the furniture is a time and back saver.
    Good point on the heaving. With all new support posts and footings, I'll have to wait and see if mine does any settling/heaving.
  13. bogieb
    The plastic strips have worked out great at keeping rain and snow off the porch as well as cutting the wind tremendously. During the day, the porch will be a bit warmer than the "outside". If it is sunny, it can be warmer by as much as 5*.
    During the day the temp on the porch is a little warmer than the "outside". If it i sunny, then the difference can be by as much as 6*. And then during the night the temps even out.
  14. Canadian border VT
    So is it 5 or 6 degrees bogieb ?
    metalcuttr, wildwest, bogieb and 2 others like this.
  15. eatonpcat
    metalcuttr, bogieb, wildwest and 3 others like this.
  16. bogieb
    I obviously didn't have enough caffeine yet and got interrupted by a cat butt before finishing, then forgot I'd already written some of it. I was trying to write that it can be as much as 5-6*.
    But yesterday was a clear, sunny day (rare to see any sun, so this was a special treat. The back porch was 8* warmer.
    Note that "Garden" is actually the north side of the house in the window sill of the garage. This unit only lets you choose names from a prepared list. And, in order to get future weather guesses, one of those picks has to either be "Garden" or "Outdoor" - I didn't have to press the choosing button thru as many names to get to Garden :D.
    I bought this several weeks ago specifically to determine the differences. It replaced the previous station that only had 1 sensor that was on the back porch.
  17. wildwest
    Nice for your stray kitty too!
    metalcuttr, bogieb and Chvymn99 like this.
  18. Canadian border VT
    Oh bogie now your starting a dance routine
    5 6 7 8?
    Or a guy I knew had 4 nephews called them 5 6 7
    8 … a quizzical look… Watts
    None is that bright
  19. bogieb
  20. bogieb
    Getting huge gusts of wind right now. The plastic strips are working well at keeping the porch from being windblown. Granted, the back porch does not get as much wind as the front of the house, but when the whole house is shaking and the wind is howling, during previous winters the back porch was no fun to be on. Now I can stand out there just fine :thumbs:
