Stove Damper... yes or no
Discussion in 'Modern EPA Stoves and Fireplaces' started by Old Nate, Nov 7, 2023.
  1. Old Nate
    Old Nate
    Western PA
    Stove Top Adapter...
    - With damper
    - Or No damper?
    My previous stove (Jotul 500) did not have a damper, and I thought it worked just great. I save $20 if go without, but I recall some people on here really standing behind getting a damper... this is going on an old Vermont Castings Intrepid that I restored and am putting in my dining room.
    Wildbill, theburtman and wildwest like this.
  2. brenndatomu
    Yes, damper.
  3. Warner
  4. theburtman
    theburtman
    I've been glad more than once that I installed one.
    Hoytman, Wildbill, yooperdave and 3 others like this.
  5. Dok440
    Dok440
    NorCal
    In the stove pipe? I've never even seen one. I wonder if the code is different around here? When would you use it?
    Wildbill and brenndatomu like this.
  6. theburtman
    theburtman
    I use mine when the wind and atmospheric conditions are such that the fire runs away. Temperatures just keep climbing even with the draft closed. It doesn't happen often but when it does the damper helps.
  7. Warner
    Not sure what the code is here there are no inspections. Been around wood stoves for as long as I can remember. I don’t recall ever seen a stove without s pipe damper.
    I look at it like a fire extinguisher, you might not need it but it isnt expensive and if you do need it you need it now and you’ll be glad you had it.
    Hoytman, Wildbill, yooperdave and 2 others like this.
  8. yooperdave
    Yes, install the damper!
    I even put one in my fish shack for the small wood stove that has a 3" flue.
  9. Warner
    That
    that looks nice, do you use it for ice fishing?
    Hoytman, Wildbill and yooperdave like this.
  10. buzz-saw
    buzz-saw
    Ct.
    Yes "Damper" , worst case don't use it just leave it open.
    You would hate to want or need one and not have it there , you know how that goes.
    Now or maybe later , I pick now to be safe. The aggravation of having to do it later is worth the cost any day.
    Hoytman, Wildbill, Softwood and 2 others like this.
  11. buzz-saw
    buzz-saw
    Ct.
    Thats kind of cute.
    Nice looking for a " shack".
    Wildbill, yooperdave and brenndatomu like this.
  12. RCBS
    Yep. If nothing else it should allow you to get longer burn times. If you put it in and don't 'need' it, it can sit there harmlessly in the open position. The older stoves don't usually have much restriction on chimney flow like all the new EPA stuff does and are more prone IMO to get rowdy than the newer ones.
  13. Stinny
    Damper... ayuh, good idea.
  14. Monadnock Monster
    Monadnock Monster
    Perfect timing with this thread as I just decided today that I need a stove damper! My draw isn't too too excessive, just enough for me to decide I want to tame it down a little.
    Problem is that my piping is hard to access.... it's out the back of the stove and up a masonry chimney. Very little room to work.
    However, I have plenty of space to install one on the intake side. (My stove's plumbed with an outside air kit, and the hose for that is super accessible.)
    No reason I can't put a little damper on the intake side, right?
  15. brenndatomu
    What stove is it? Some stoves have air sources outside of the OAK, so throttling the OAK would not have the desired affect in that scenario...not sure about a stove that gets 100% from the OAK...
    Wildbill likes this.
  16. Monadnock Monster
    Monadnock Monster
    Yah, sorry about that, guess I should get that in my signature....
    It's a Hearthstone Heritage. I've heard that some air is pulled in from a different source than just the OAK, but the diagrams aren't clear. Regardless, I don't need to reduce it very much
    I was playing around with it today and covered about 3/4 of the opening and was able to noticeably dampen the burn.
    wildwest and brenndatomu like this.
  17. yooperdave
    I should and I could but I don't. :picard:
  18. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Mines a yes vote.
    Hoytman, Wildbill and brenndatomu like this.
  19. Wildbill
    Wildbill
    SW Va
    Without a damper I'd never have enough wood. The Wife's from Texas and it's always 80deg. there.....
  20. Old Nate
    Old Nate
    Western PA
    Wow! Overwhelming yes vote for the Damper! I ordered it on Wednesday morning. Glad I did. Someone said it, and it's true, do it now so you don't have to do it later. Thanks!
    theburtman, Hoytman, Wildbill and 2 others like this.
