Heatmaster G4000 Install
Discussion in 'OWB's and Gasification Boilers' started by morningwood, Nov 24, 2022.
  1. morningwood
    morningwood Administrator
    No clue. All of my yard hydrants are connected to a well. The garden and grass I planted are getting plenty of water. :singingintherain:The house is connected to "city" water. I'd assume that the water company is asking people to cut back on lawn watering etc.
    We are dry too, we haven't had a drop of rain in 20 something days at this point. My pastures are starting to dry up. Bought some extra hay......just in case.
    brenndatomu likes this.
  2. morningwood
    Season 2 officially started today.
    My dealer is no longer a dealer so it's been a fiasco trying to get a replacement low water sensor. I emailed HM a few weeks ago, no email back. Called my local dealer last week, still waiting on a call back. There's a pretty active Heatmaster Facebook group. Posting about my issue is probably my next move, they aren't too keen on "bad press" about Heatmaster.
  3. brenndatomu
    The guy up by Mansfield? He didn't impress us at all...dad bought from the guy over in Lisbon.
    morningwood likes this.
  4. morningwood
    Yep, I can't say I'm too impressed so far either. Heatmaster removed their direct number from their web site but you can still find via it a Google search. :DI called them and complained, they won't ship the part to me directly but said that I should be hearing from the dealer in Mansfield.
    I don't see a dealer in Lisbon anymore. I see dealers in Mansfield, Marietta, and the Portsmouth area now. The dealers of these OWB's seems to change like people change underwear. Seems like a broken business model IMHO.
  5. brenndatomu
  6. morningwood
    That's interesting, my phone and work computer show the below. I don't see the Portsmouth dealer anymore though, but it shows one now in Oakwood.
  7. brenndatomu
    Its not just HM, it seems to be a thing with OWB's in general...everybody wants to be a "dealer", very few are dealers like what you would expect to see with a shop and a showroom, parts inventory, etc...
    It must be the difference in results from our different zip codes...
  8. jrider
    jrider
    Pretty terrible they would rather you wait then ship you the part directly. Hope you get what you need asap!
  9. morningwood
    The local dealer called yesterday afternoon, and I went to the dealers place yesterday to pick the part up because our schedules didn't align up for the rest of the week.
    I guess the squeaky wheel gets the grease. :D
    Farmchuck, brenndatomu and jrider like this.
  10. morningwood
    Cleaned the boiler up last weekend. Final tally for the year was roughly 3.33 cords if I'm counting by totes. It could be a little more or maybe a little less. I do know that two totes I burned early in the year was pretty much half rotten stuff I should have left in the woods. Have a little over a cord of pine on deck for this year. I've never burned pine but my plan is to mix it with the ash I have, and I plan on stretching the pine out over a number of years.
    The only problem I ran into this past season was self induced problem. The square air hole between the fan and the 6" double wall pipe started to get plugged up and it caused some gassing issues a few months ago. Once I got it figured out, and cleaned out it ran as great as always. Just need to add that to my mid year maintenance list.
    Farmchuck and brenndatomu like this.
  11. morningwood
    Wood usage update: Burned about 3 - 3.5 cords this past winter. A mix of ash, oak, and maybe a little bit maple. We had real winter for a few weeks this past year and the boiler has zero problems keeping up. Since it ran so much, the firebox was really clean during that time frame.
    One self-induced issue. A bird made a nest in my extended chimney which caused the boiler to plug up with creosote. Plan on putting some stainless mesh in the chimney cap this summer.
    I had to replace the bearings on the fan in the middle of the winter. I have a second fan, so I just put that it the boiler and replaced the bearings in the one that was making noises. Fan bearings going bad is a known issue with the early GXXXX boilers. It takes maybe 15 minutes to replace the bearings in the fan.
    jrider, Farmchuck and brenndatomu like this.
  12. brenndatomu
    And they have updated fans now too...the new style has larger bearings (I think) and are designed to not allow as much exhaust heat get to the motor. These can be retrofitted to the older 4000/7000/10000 G series units
    Farmchuck and morningwood like this.
  13. morningwood
    I called our favorite dealer, and he wanted $350 for the retrofit kit, and new fan. I can buy the older style fan all day long for $90. Bought a whole bunch of SKF bearings for $4 each on eBay for the older fan. The problem a few of us are seeing now is that the fan bearing housing is starting to get a little sloppy. I'm guessing that I'm at around 6 - 7k hours of runtime. My controller lost my runtime history two years ago and it was around 4k then.
