Informal Chain Life Poll
Discussion in 'Chainsaws and Power Equipment' started by Elm-er Fudd, Oct 25, 2023.
  1. Elm-er Fudd
    Elm-er Fudd
    Kansas
    Just curious how far you all take your chains before you chuck them in the trash. I’ve heard some go halfway down the tooth, some go to the angle guide line, and some go further. I’m in the last category…I take them down to pointed triangles…seems much beyond that they start breaking off regularly. Although I have never put a stopwatch on them, I don’t seem to notice a lot of difference between factory new and pointed triangles, maybe even a bit faster at the halfway point. What do you guys and gals do?
  2. Eggshooterist
    Eggshooterist
    Erff
    Pointed triangles here.
  3. jmb6420
    jmb6420
    Grand lake, Oklahoma
    I go until there’s not enough left to sharpen.
    Mike in Okla
  4. Chud
    Chud
    I sharpen to the marker and stop. I don’t think it performs as well at that point and bore cutting can be impossible.
  5. buzz-saw
    buzz-saw
    Ct.
    ^^ This about where I stop. At that point it has done it's duty verses the cost.
    It is part of the cost of running any equipment.
    Like brakes on your car , it is a wear item.
  6. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Run em past the guide line for sure. Ain’t done till theys spittin out teef
  7. Ronaldo
    Ronaldo
    I run em till a toth or two breaks then I know it's time for a new one.
    Sent from my SM-S536DL using Tapatalk
  8. RCBS
    I claim victory once I get to the guide line. The chains are not trashed though. They get 'put in' when I have a stump to flush or I know for a fact I'm gong to be sawing dirt. Beyond that...I have a friend who like to play with a forge. Chains are of very good steel, so are bars.
  9. Highbeam
    Highbeam
    With a light touch from the grinder and if you can avoid rocks and metal, I find chains last many years when cutting 5 cords per year. Maybe softwoods are easier on chains.
    I go all the way until the first tooth breaks off. Why not? They work until then. Not all chains have that guide mark.
  10. brenndatomu
    Just one?!
    Rich guys...:picard:
  11. Highbeam
    Highbeam
    Yeah, by then the rest are getting pretty silly. Wouldn't want it to cut crooked so I would have to snip off a tooth facing the opposite direction.
  12. The Wood Wolverine
    I too run em till I see a cutter break off.
  13. MasterMech
    At least to the witness marks/line. Unless I done really messed 'em up. :rofl: :lol:
    brenndatomu likes this.
  14. saskwoodburner
    saskwoodburner
    I'll run a chain until it has less teeth than an old tom cat. Everyone needs at least one stumping chain lol
    Softwood and brenndatomu like this.
