Best cabinet saw fence
Discussion in 'The DIY Room' started by Screwloose, Oct 12, 2023.
  1. Screwloose
    I just picked up a powermatic 72 14" cabinet saw and I'm looking for a bulletproof fence.
    It came with a biesemeyer fence (now in the dumpster) and I'm looking for something better, much better.
    Not trying to bash the biesemeyer as I have other saws with them and for general use they are adequate.
    Any thoughts are appreciated.
    Not against building my own but I don't want to reinvent the wheel.
    Thanks!
  2. buzz-saw
    buzz-saw
    Ct.
    I thought this was supposed to be a top-of-the-line brand.
    We do have a powermatic saw here at my work , when I get a couple minutes I will take a walk out and see what it actually has for a fence.
  3. buzz-saw
    buzz-saw
    Ct.
  4. Screwloose
    That's what I have on my model 66 saws and is quite fine for general use. The problem is with heavy sheets of plastic like 3" thick UHMW for example it just thumps off the mark.
    Also I want a DRO and that will require a rigid, non lift off fence.
  5. buzz-saw
    buzz-saw
    Ct.
    I don't know about their fences , but good to know.
    I like the thought of a DRO , I put one on the sawmill and love it. One on the table saw might be something to seriously consider.
  6. Screwloose
    How nice it would be to make a test cut, measure it and punch the number in the readout for a actual zero.
    Flex, kerf ect. all taken into account.
  7. buzz-saw
    buzz-saw
    Ct.
    You got me thinking now. After I get home tonight I need to take a couple measurements to see how long the reader bar has to be.
    You know where this is going.:thumbs:
  8. Screwloose
    Why yes I do!
    I'm also thinking a fine adjustment knob and secondary locks.
  9. lukem
    Sounds like you should just build one yourself. I doubt you are going to find one that takes a beating and has fine tune adjustability.
  10. Screwloose
    It's looking that way. Seems like choices are limited on 14" saws anyway.
  11. chris
    look up " Very Cool Super Tools" That should get ya going on diy project.
  12. T.Jeff Veal
    I'll check the fence we have on the Delta saw.
  13. Screwloose
    This was a very good suggestion although quite the rabbit hole!
  14. Ward Hoarder
    Ward Hoarder
    West Virginia
    Delta Uni Fence has done me well.
  15. T.Jeff Veal
    I think the one on our saw is the Excalibur. It has micro adjust and T-slots made into the top rail to hold jigs.
  16. buzz-saw
    buzz-saw
    Ct.
    I have a Delta at home myself , embarrassed to say without looking I am not sure of what the fence actually is.
    I do know when I bought it I went for the upgraded fence and cast iron wings on the sides of the table.
    If I can remember I will check to see. Now I am wondering myself.
