Hope They're not Planning to Hand Split This
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Oct 10, 2023.
  1. buZZsaw BRAD
    You ever process any Joe?
  2. jo191145
    Nope. Seen some up for grabs but I already had heard to stay away from camouflage trees :)
  3. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    Ice storm of 2007 , we were out of power for 14 days and below freezing 10 of those. The last wood we had was sycamore. Neighbors on moths sides and myself all pitched in on the firewood procurement those two weeks. The three of us took turns with maul and ax on a few big rounds- it was the absolute worst. Fortunately my fireplace in that home accommodates about a 36” piece of wood ( built in 1922) so I was loading it up with about anything. Ended up cutting in to small 12”-14” rounds to split easier , still sucked tho. Rather go to the dentist
  4. buzz-saw
    buzz-saw
    Ct.
    I like the bark , perfect camouflage.
  5. WinonaRail
    WinonaRail
    Indiana, US
    I have some decent size trunk pieces 20"+. I've found it to spilt like butter with a hydro, dries fast and doesn't make much of a mess. I haven't burnt it personally but I imagine it would make a decent shoulder season wood. I would take every log I could get my hands on as a seller.
  6. Paul bunion
    Paul bunion
    In the past 20 years I’ve only received one Sycamore log. I got thru it. I’d say it’s more of a shred than a split.
  7. lukem
    The only problem I've ever had splitting sycamore is picking it up. That stuff is crazy heavy when green. There's more water in it than there is wood.
  8. Chud
    Chud
    Cutting Sycamore in July is the 4th level of hell. The leaf dust is a respiratory irritant and makes me cough and sneeze to the point of nausea and heaving.
  9. Locust Post
    Yes I have hydraulics and it split fine once I noodled the huge rounds into qts.
  10. buZZsaw BRAD
    Seems to grow next to rivers/streams in my observations. A few growing next to our river here.
  11. Eggshooterist
    Eggshooterist
    Erff
    You should give them a couple senix saws to noodle it.
  12. T.Jeff Veal
    I cut some about 24 yrs years ago on a job we did, thinning trees in a back yard. About 15 total, sycamore and sweet gum. Only equipment we had then was 1 saw, 4 wheeler and Yard machine 25 ton splitter. Oh, did have climbing stand to get cable up high to pull trees with FIL's Jeep.
    I had better luck with the gum. It would eventually pop open, with sycamore, run splitter down, then use axe to cut all the strings. Parents got the wood, dad said it burned better than a snowball.
  13. Old Nate
    Old Nate
    Western PA
    I'm glad I came across this thread... a ways back a friend offered me sycamore he was going to have cut down and I knew it wasn't any firewood hoarders dream wood so I turned it down, mostly because I didn't have the time to pick it up and process it, but I had thought that I would take him up on it if he still had it available... sounds like it's just not worth the time and effort... more like a headache.
  14. buZZsaw BRAD
    Try a few rounds with your sledge & wedge, maul and axe for chits and giggles and report back.
    You made the right choice the first time though.
  15. Locust Post
    Don't be skeered
  16. Yawner
    Yawner
    Louisiana
    I have split sycamore before with a splitter and had very little problem. I let it dry a few months before splitting. It was NOTHING like elm.
  17. RCBS
    That's Blocking and Pallets, not firewood.
  18. Rick Capper
    Rick Capper
    Pennsylvania
    I’vesplit it before many times.put one round on the splitter and push it through.don’t expect it to pop in half.just put a new round or piece on splitter behind it and shove it through!works every time.my old lickety splitter does the job
  19. Timberdog
    Timberdog
    Az
    Like elm, hydro required for large amounts, unless you are a glutton for punishment. But once seasoned burns decent. Not best but not worst either. When it’s green it has a weird blood red look that turns tan or light brown as it dries.
  20. The Wood Wolverine
    Speaking of hand splitting (which I am not a fan of) buZZsaw BRAD, thinking about investing in a Fiskars to break down big rounds of oak instead of noodling. This week I'll hopefully be helping both dad and son. Which would you recommend, X27 or Isocore? Looking to half or quarter these so we can easily lift onto the splitter.
    Sons mostly chestnut oak:
    And dad's black and pin oak:
