Moisture meter?
Discussion in 'The Wood Pile' started by RCBS, Sep 27, 2023.
  1. cezar
    cezar
    KY
    I like the General one. My only comment is that if I burn wood at 15-20% on my meter, its way too wet. Obligatory, yes this is on a freshly split piece at room temperature along the direction of the grain.
    So I just check for < 15% and go off that.
  2. Barcroftb
    Barcroftb
    The Mitten
    I mean the cheap moisture meter, which all the suggestions and pictures have been so far, are really only accurate to within -/+5%. So a split with an actual moisture content of 20% could read anywhere between 15% and 25% on the moisture meter.
    They really aren’t meant for more than a ballpark idea really. Unless you want to spend more on a pro unit that can be calibrated. I tend to like Dennis’ 3 year plan myself. Takes all the guess work out of it.
    RCBS, Eric VW, barns1 and 3 others like this.
  3. Ward Hoarder
    Ward Hoarder
    West Virginia
    X2 for the General
    RCBS, barns1 and In the Pines like this.
  4. SD Steve
    SD Steve
    South Dakota
    I need one, just be accurate
    RCBS likes this.
  5. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I haven't said this in quite a while: "The best device for measuring the moisture content of firewood is a multi-year calendar!"
    :rofl: :lol::p
    RCBS, Buzz Benton, Farmchuck and 6 others like this.
  6. Eric VW
    In the most ideal situation, I would always agree. But with limited storage space and timing in regards to selling, RCBS nails it with this-
    :handshake:
  7. Theashhole
    Theashhole
    Osceola, In
    RCBS and buZZsaw BRAD like this.
  8. billb3
    I have a General.
    I only bought it to show someone how well seasoned dead standing oak can be.
    It has come in handy for some firewood I haven't known the history of besides it's mine now.
    I've also used it to test before painting.
    In the Pines likes this.
  9. JiminyKicket
    JiminyKicket
    Seattle
    FBM ad, impressive wood yard!
    the last pic of the ad showed his MM reading:
    2.1%! He is not in an arid part of the state. And he makes no mention of a kiln.
  10. brenndatomu
    Even if he had a kiln, that meter is out totally out to lunch...they don't even kiln dry lumber that low, no point in it, as soon as you take it out equilibrium will take MC back up to 8-10% (or 12...just depends on local/time of year/weather)
  11. billb3
    wrong mode on the moisture meter
  12. BuckeyeFootball
    BuckeyeFootball
    Got the same one its great. Only annoying thing is remembering the setting for each species so I taped a cheat sheet to the back.
    In the Pines, RCBS and brenndatomu like this.
  13. RCBS
    I have always found it odd that the specie is even of consequence. There are sciences at work that I obviously do not understand. The meters measure conductivity IIRC, how does that change I wonder from specie to specie? I suppose differing wood has differing conductivity...still seems odd to me.
  14. Old Nate
    Old Nate
    Western PA
    Yeah this seems odd to me to... I don't get it. I might pony up the dough and buy another General moisture meter. I always liked to check right when I split and stacked and then monitor it... as I work my way through my stacks.
    In the Pines and RCBS like this.
  15. The Wood Wolverine
    I read resin content in different woods can alter readings (ie conduct the electrical signal better/worse) so they have to make different curves to compensate.
    Good thing for me is all the wood I'm getting is in the A setting. Great idea about the cheat sheet. I may have to steal your idea and put on it just the woods I could get. :handshake:
    buZZsaw BRAD, In the Pines and RCBS like this.
  16. BuckeyeFootball
    BuckeyeFootball
    I thought it had to do with different densitys but I could be wrong.
    RCBS likes this.
  17. In the Pines
    In the Pines
  18. RCBS
  19. Old Nate
    Old Nate
    Western PA
    I was at Lowes the other day and saw a Kobalt moisture meter with pins... I'm sure it works just fine and will give a fairly accurate account of ones wood moisture content. True, if I CSS and wait 3 years to use said wood I can be pretty sure it is dry, but I do like to monitor it and have some kind of gauge along the way during that 3 year window.
  20. Barcroftb
    Barcroftb
    The Mitten
    That’s how I’ve looked at it. Great tool for a general idea of what’s going on with the firewood. Interesting to get a feel for the differing dry times of various species. It’s fun to see the difference in 2 year oak vs. 3 for example. Just another tool in the shed to mess with.
