Smurf village
Discussion in 'The Wood Pile' started by Ohio dave, Sep 20, 2023.
  1. Ohio dave
    Ohio dave
    Akron, OH
    For those of you that cut IBC tote liners to use as covers what do you use to cut the liner?
  2. JimBear
    JimBear
    We cut a couple for other purposes with a sawzall & it worked well.
  3. Chvymn99
    X2
  4. brenndatomu
    I just used a circular saw
  5. Rickyblazin
    Rickyblazin
    Pottstown PA
    My brother used his top handle chainsaw…i probably would go with a circular saw
  6. buZZsaw BRAD
    Circular saw with a standard blade will easily slice through plastic. Sawzall or oscillating saw will work great too. Tin snips or shears will work as well.
  7. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Sawzall in the past. Works quite well.
    Might try my Milwaukee hatchet next time
  8. JiminyKicket
    JiminyKicket
    Seattle
    I thought this post was going to be about a log covered in mushrooms.
  9. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Just cut mine with Sawzall and metal blade. Not straight cuts, but not too worried about that. Going through some ideas to raise them up on the 275-gallon totes so I can load and unload totes without the need to remove them. Only have 8 from my 4 330-gallon totes to play with.
  10. buZZsaw BRAD
    Some members have multiple IBC totes with the plastic roofs and it does look like a gnome village. T.Jeff Veal comes to mind.
  11. Woodwidow
    The Australian member comes to mind as well. I forget his name.
  12. buZZsaw BRAD
    leoht or HuskyMatt ???
    HuskyMatt, metalcuttr and brenndatomu like this.
  13. Woodwidow
    leoht is the one I am thinking of. He had a whole village among the trees.
  14. brenndatomu
  15. Woodwidow
    brenndatomu thanks for finding the picture. they do look like little houses with turquoise chimneys.
  16. Stephiedoll
    Stephiedoll
    Omaha, NE.
  17. jo191145
    I’ve never cut one. Put the blade backwards in a skilsaw would be a good option. Cuts vinyl siding nice. A masonry blade would work too.
    theburtman and brenndatomu like this.
  18. brenndatomu
    I used the standard wood blade...cut like buttah
