Grease for Stove Door Latch
Discussion in 'Modern EPA Stoves and Fireplaces' started by foothillsfire, Sep 19, 2023.
  1. foothillsfire
    foothillsfire
    Alberta
    On my PE Neo 1.6 I notice the door latch rubs a little bit, it is at least less smooth than when initially installed.
    Can't find a picture of the exact model but its similar to this:
    Should I be greasing the contact point on the latch? If so what kind of high temperature grease is appropriate. On hand I have gun grease so I suspect I may have to go find something else.
    Screwloose and Backwoods Savage like this.
  2. brenndatomu
    Never seize works...graphite powder can too, but can be messy (the NS can be too if not careful!) and I've also heard of people using cooking spray (like PAM)
    Screwloose, Buzz Benton, RCBS and 2 others like this.
  3. Highbeam
    Highbeam
    I even tried gear oil once. Man did that stink up the house.
    high temp caliper grease cooked off. It’s just a hot place. The powder might be best.
    Screwloose and wildwest like this.
  4. wildwest
    Eghads!! Husband used that in his 79' Blazer, unforgettable. Other one was we used Penofin on our back deck and oak front door, that stuff reeked for years when the sun hit it. Hope yours went away much sooner.
  5. wildwest
    HB, what's your pipe configuration on your Princess?
  6. Eggshooterist
    Eggshooterist
    Erff
    My vote is bacon grease...
  7. brenndatomu
    I dunno why I gained 50 lbs over the winter doc!
  8. RCBS
    Copper based anti seize. Little dab'l do ya!
  9. foothillsfire
    foothillsfire
    Alberta
    Good idea, looks like its rated up to 1800 degrees. Time to hit up Canadian Tire.
  10. coreboy83
    coreboy83
    NW of Twin-Cities
    I used graphic powder on my Alderlea door catch. 2 seasons, and doing great
    Screwloose and Eggshooterist like this.
  11. Highbeam
    Highbeam
    All vertical double wall to insulated class A.
  12. Highbeam
    Highbeam
    it doesn’t stay grease very long and burns off to a powder. Leaves a mess too. Not a bad option because even the powdered antiseize is slippery.
    brenndatomu likes this.
  13. brenndatomu
    Standard aluminum or copper based anti seize is good for that 1800*F range, but nickel based takes it to roughly 2600*F...usually doesn't cost much more either. I keep both copper based and nickel based around, but use the nickel much more...
    Warner likes this.
  14. Warner
    Are y’all saying anitsieze dries out in heat applications? :rofl: :lol:
  15. Highbeam
    Highbeam
    Absolutely. Turns to a powder coating which is likely what stops seize and offers some lubrication similar to a graphite powder.
  16. Warner
    There was some discussion awhile ago about what to use on brake caliper pins. I suggested not using antisieze and got an earful. Anyway no need to beat that horse.
    Jeffrey Svoboda and brenndatomu like this.
  17. Highbeam
    Highbeam
    i have a bottle of stuff called caliper pin slide grease. I hope that’s okay for caliper pins.
  18. brenndatomu
    I'd sure take AS over the rust/crud that's in there on many vehicles!
    moresnow likes this.
  19. Ohio
    Not Ohio
    I have used graphite powder with good luck. My old stove used to squeak loud when I opened the door. I used the graphite powder and it was whisper quiet after that. There is also a product that is graphite aerosol spray. Spray it on and air dry.
    Highbeam and brenndatomu like this.
