Metal
Discussion in 'The Wood Pile' started by Buttermilk, Sep 13, 2023.
  1. Buttermilk
    Buttermilk
    Central AR
  2. Buck55
    Buck55
    Rochester, NY
    Dislike!
    buZZsaw BRAD, Chaz, FarmerJ and 5 others like this.
  3. buZZsaw BRAD
    Always lurking. Nice that oak will give you a better warning than other woods.
    Stephiedoll, Chaz, jrider and 4 others like this.
  4. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    Would have been a good day to buy a lottery ticket:picard:
    Chaz, T.Jeff Veal, Buttermilk and 5 others like this.
  5. Chvymn99
    Some days its better to be lucky than good... :D
    JD Guy, Chaz, jrider and 7 others like this.
  6. T.Jeff Veal
    Yep that was close.
  7. The Wood Wolverine
    I've hit a few milling. Plow right through a nail but a screw will halt operations. Ya got lucky for sure.
  8. Monadnock Monster
    Monadnock Monster
    How does oak or any wood give a warning? Genuine question. :emb:
    I don't really have to worry about nails or metal in my trees. There really isn't anything in the woods around my property, though I know on FBM it's a risk. Seen some, too, but always been lucky.
    Is there a way to 'read' the wood to know if metal's in there?
  9. The Wood Wolverine
    Oak gives that blueish stain. If you see it, be prepared.
    JD Guy, T.Jeff Veal and Sawdust Man like this.
  10. Sawdust Man
    Sawdust Man
    Blue stain is the number one sign of metal.
    T.Jeff Veal likes this.
  11. Monadnock Monster
    Monadnock Monster
    Like a blue stain on the bark? Is it obvious?
    buZZsaw BRAD and T.Jeff Veal like this.
  12. Sawdust Man
    Sawdust Man
    The stain shows up on the end of a log after it's been cut.
    Usually the only thing you'll see on the outside of a log is just abnormalities or lumps in the bark.
  13. Sawdust Man
    Sawdust Man
    Anytime you see three or four evenly spaced scars at fence wire hight(s) just assume it's wire and junk it!
    When I see any suspicious formation in the bark of a log I proceed with extra caution.
  14. buZZsaw BRAD
    Cant get much closer than that although i do recall coming fractions of an inch from a roofing nail. I spotted the rusty head after i made the cut.
  15. buZZsaw BRAD
    As WW said red or white oak have that staining that extends above and below where the metal is present plus its usually broader too. If you see the chips being ejected change color, beware and slow your chain speed to a crawl. Most other trees will have only a small area of discoloring around the metal IME.
    I have a really good pic of it that ill dig up.
  16. buZZsaw BRAD
    Notice the stain on the end cut and how it extends in the split? All pics from same tree. There were some splits that were entirely the purplish color. Most metal ive ever run into in one tree.
    This was a 36" pin oak i bucked using the 36" bar and it was teeming with metal. Barbed wire, guy wire bolt and nails. It was a miracle i didnt hit any. Ever sharpen a 36" chain? Not fun on a normal sharpening let alone hitting metal. IMG_4184.JPG IMG_4186.JPG IMG_4187.JPG IMG_4189.JPG IMG_4190.JPG IMG_4191.JPG
  17. Erik B
    Erik B
    Western Wisconsin
    I have also seen blue stains from metal in paper birch trees.
  18. T.Jeff Veal
    You did get lucky with that one, my friend
  19. eatonpcat
    That sucker was loaded!!
  20. buZZsaw BRAD
    For sure. The chain saw gods were looking out for me. IRONically :doh: it was the 500's inaugural run back in 2021.
