Which way to face new stove location installation?
Discussion in 'Modern EPA Stoves and Fireplaces' started by wildwest, Sep 8, 2023.
  1. wildwest
    Installing a new stove soon, it's in a ~8 x 8' alcove off the living room, with a ~6' opening (standard sliding glass door size).
    First I thought it should face the living room so I could see when it needed to be stoked, then read cat stoves don't flame. New to cat stoves...
    Second, thought if I cant see flames, might as well face the door to our garage and it'll be easier to chuck wood in from there, just a few feet away, and less steps on flooring that can be slippery with snowy shoes (which will melt quickly since that room will be really really warm).
    Third, well duh, it has an attached blower, silly for the stove blower to be facing the garage, we need it facing the living room.
    Both of us are keen on chucking wood directly in from the garage door. I'm not keen on having the blower facing the garage but dig the easier stoking, WWW said that room will be SO hot the heat will pour out on it's own.
    Thoughts?
  2. Screwloose
    My vote is for the easier stoking. The heat will make its way out even if the blower is not aimed in the best direction.
    The stoking goes on and on and on...... might as well make it the most efficient way.
    Is it possible to get it set up to redirect the flow from the blower?
  3. MikeInMa
    My cat stove has flames.
    NewYorkNewJack, barns1, Eckie and 8 others like this.
  4. Backwoods Savage
    Face the room. You can keep an eye on things that way, including when to add wood.
    In addition, you need to know when to engage the cat and know if it is working.
    Besides, the only backside I want to stare at is not an inanimate object. Keep the home looking like a home.
  5. Screwloose
    That looks really, really nice. Definitely if that's the case I would want to see the flames.
  6. MikeInMa
    Thanks! We enjoy it.
  7. The Wood Wolverine
    I’d have it face the room you can view it from. You still get dancing secondaries to watch.
  8. Eric VW
    Put a runner down from garage door to feed door.
    Softwood, barns1, metalcuttr and 6 others like this.
  9. billb3
    C'mon, man ! It's not like watching coal glow.
  10. Locust Post
    Face the room, my cat stove has some real pretty dancing ghost flames at times.
  11. moresnow
    moresnow
    What make/model stove ?
    Plenty to enjoy looking at in a Cat stove.
  12. wildwest
    BK40, Blaze King King.
  13. moresnow
    moresnow
    A very proper stove selection, Enjoy:yes:.
    Study the operator manual closely while you are waiting.
  14. wildwest
    Stove will face the living room, thank you fellas' :) Very tempted to face it sideways to living room but this funky old 3 additions house is weird enough, Dennis's comment was spot on! And now I know there can/will be flames. I had iron doors for a couple decades and had to get up and open them to see, despite the glass on the pellet stove glass wood stove is new to me.
    I'll have 86" of floor from front to back of room, still allows decent clearance in front of the stove for loading, ~ 3' , as well as the door opens in the correct direction for our situation (or swings left, garage door on right where splits will be stacked).
    Floor runners like Eric VW suggested, one in front of the stove, smaller one in front of garage door. Densdeck under vinyl flooring and will be on the walls eventually too. It'll sit on concrete roofing pavers that add another 2" of height for stoking.
    Pipe will go 45* out to enclosed porch with cleanout tee there (sheltered from wind!!!!!!!!!) and up through there. Hope I can find a clean out tee that accepts a 45* angle. I'll ask the dealer, maybe two 45's could be a lot less $, but don't want to add extra stack height, we'll see.
  15. wildwest
    Edit, bummer, door on other side and wall stud alignment, will not have 3' in front of the stove, we have to bring it forward.
    metalcuttr and Backwoods Savage like this.
  16. Hoytman
    Hoytman
    OH
    :p:rofl: :lol::D
  17. Hoytman
    Hoytman
    OH
    I think you are going to love that new BK 40. It’s the closest thing you can get to my black rock burner, minus the blue flames of course, as well as minus having to empty ash twice a day in winter.
  18. wildwest
    Oh good to hear, thanks! I know a cat stove will be a learning curve (we had one the first winter we moved here but the cat was toast, 1/2 already crumbled off when we got here), so in reality, new to cat stoves.
    Why twice a day in the winter?
  19. Hoytman
    Hoytman
    OH
    I was referring to emptying ash from my coal stove twice a day in winter.
    You’ll empty ash in that big BKK probably once every two weeks, or maybe once a month. That’s a good thing.
    My coal stove has the same type thermostat on the back. The BK thermostat…once you get used to it you’ll wonder why you ever had a stove without one. Every wood stove should have one in my mind.
    metalcuttr and wildwest like this.
  20. Old Nate
    Old Nate
    Western PA
    Can we see a picture of your setup? I'd like to see the alcove and the orientation of the room... maybe I'm not thinking this out proper, but I feel there is only one way to place the stove... usually not debatable, unless this is all new construction and you have several different options maybe...
