My T post failed Dennis
Discussion in 'The Wood Pile' started by HDRock, Sep 12, 2014.
  1. HDRock
    :DNot to big a deal, the wood has to be moved anyway
  2. rottiman
    End pressure can be unreal. That's why I chain across the rows, IMG_5092 (Custom).JPG tying the ends to each other. My rows are 7 1/2 high by 9' wide. One blow out with that would create havack in my shed.
  3. papadave
    You know what Dennis is going to say, right?
    If only you'd cross stacked the ends..........:headbang:
    I had a couple of my posts blow out that had been in the ground for several years......it was expected.
    A PITA, but expected.:D
  4. Shawn Curry
    Shawn Curry
    Western NY
    :doh: :picard:It knows the fate that soon awaits it... It's trying to escape! It's punishment should be to go to the head of the line on Burn Row!
  5. basod
    basod
    Mount Cheaha AL
    Better than having the whole pile fall over backwards:whistle:
  6. Chvymn99
    Yep, I had a skid bow out on me this summer. I had to unload a bit tye off with a #9 wire and reload. Quite abit of pressure as they dry and realign. Good Luck HDRock
    Backwoods Savage and HDRock like this.
  7. concretegrazer
    concretegrazer
    Southwest MO
    I've had it happen as well.
    HDRock likes this.
  8. bassJAM
    bassJAM
    Cincinnati, OH
    Did the t-post bend, or did the ground give way? If the post bent, you might get a little more strength by turning them around 180° so that the "fin" side is against the wood, although that's just a guess. Or run a wire/cable along the top, tightened between the 2 ends.
    Backwoods Savage, HDRock and Chvymn99 like this.
  9. HDRock
    The ground gave way
    I was going to run a wire along the top but didn't. :rolleyes:
    I had a space there to walk between so the other post kinda caught them from falling on the ground
  10. HDRock
    I was just out there looking again and now I see what happened, a Dang mole went through there :hair:
  11. Backwoods Savage
    Maybe a woodchuck rather than a mole?!
    I intended to post a picture or to so as not to disappoint some but for some odd reason, I can no longer post pictures.
    HDRock likes this.
  12. Backwoods Savage
    Got the picture thing straightened out thanks to Grizzly Adam.
    Take notice of the lack of t-posts in the pictures! :rofl: :lol: T-posts are for building fences! :headbang:
    This is a neighbor lady helping to load their wagon. Her husband had back surgery and could not cut. Now this year, he has had heart surgery. I might start to run low on wood if this keeps up. I don't even remember when that stack got there. Well, I do remember it but right now can't come up with the year it was done. Was all dead ash anyway. That is our atv in the background.
    This is a stack from a couple years ago or thereabouts.
    And finally, one from inside the barn. Very soon I'll be restocking that to get ready for winter.
    Shawn Curry, bassJAM, BrianK and 6 others like this.
  13. HDRock
    :thumbs::thumbs::thumbs: :D
  14. Gark
    Gark
    SW Michigan
    I did an experimental stack end with 2 metal fence posts like that. Those 2 bent outward with only 5' stack. It does help to turn 'em 90 degrees like BASSjam said. Mostly, it's back to cross-stacking the ends for me.
  15. UncleJoe
    UncleJoe
    SC Pa
    I'll bet it's happened to all of us at one time or another. :emb:
  16. savemoney
    Like a good neighbor, you are there! Earning your wings!
