Fire box surface rust
Discussion in 'Modern EPA Stoves and Fireplaces' started by Well Seasoned, Aug 30, 2014.
  1. Well Seasoned
    Anyone else get it?
    I keep a large dissicant pack inside the fire box, but still get alittle rust.
  2. stuckinthemuck
    stuckinthemuck
    Haven't looked inside since I threw in my last split in March of last spring. Hope I am not surprised when I open it up.:doh:
  3. Backwoods Savage
    Should only be very light and the first fire will take care of it.
    thewoodlands and Well Seasoned like this.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    Same here, before I sold the Oslo I ran through it. There was some minor
    rust inside but nothing alarming.
  5. nate
    nate Banned
    Palmer, AK
    Same.. sorta. I had to run the stove a few times all through "summer". Have had a fire the last couple nights too.
  6. Locust Post
    Yep, looked in mine for the first time since shutting her down and have a small bit. I have a container of damp rid sitting in the center, but doesn't seem like anything to be concerned with. Like Sav said, first fire will take care of it.
  7. Well Seasoned
    Ok then guys..... nothing serious here, but mother nature, c'mon....... my baby is getting rusty!
    clemsonfor and Backwoods Savage like this.
  8. badbob
    badbob
    Well I will be the butthead.Clean stove when you are done.Block it off from outside air,inside air is usually lower in humidity,and being open to the outside cooling and heating causes condensation.All bare metal should be treated,whenever needed.New fire only pops off rust and scale(sometimes)and does not treat the surface.Ash holds moisture.creasote holds moisture.This will cause rust underneath.Unhooking stove from flue,cleaning/scraping and treating metal will keep unit longer lasting.Hi temp paint works well for anything that flame does not touch,otherwise use good quality graphite or moly spray.If you need to treat the metal.reply,post getting too long!!!!Bob
  9. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    My container of damp rid is now filled with water. Worked great.
    clemsonfor and Well Seasoned like this.
  10. macpolski
    macpolski
    South Jersey
    I stuffed the flue exit on the stove with leftover Roxul. Didn't think much of the rust only the possibility of creosote smell. Everything is good. BTW, I placed a 8-½ X 11 note in the firebox to remind me the flue exit is blocked! :yes:​
  11. DexterDay
    This what I do with my Pellet stoves mainly, but I have the OAK on my wood stove blocked and I close the key damper (I know that doesn't seal it, but it's something). Then two containers of Damp Rid (after the firebox has been cleaned, vacuumed, and sprayed with Pam cooking spray)
    It may be overkill, but the surface rust over time will wear the stove from the inside out. Ever seen a early 90's Ford, Dodge, Chevy? :)
    Well Seasoned likes this.
  12. papadave
    Hmmm, not that something shouldn't be done about it, because you can do what you want........but, my 1985 plate steel Ashley has some rust inside, and did every year.
    I would have to presume it happened every year after the burn season. 28 years later, and it doesn't even look close to rusting through.
    I'd worry if there were big chunks of rust falling off, otherwise, not so much.
  13. Backwoods Savage
    Right on Dave. Ours showed rust every year too. When we took the old Ashley out we planned on perhaps using it to boil some syrup but never got to do that. Finally we used it for a trash burner and after several years, someone came and wanted it. We gave it to them and they are still using it.
    clemsonfor, Well Seasoned and fox9988 like this.
  14. Woody Stover
    Woody Stover
    Southern IN
    I believe in blocking the flue as well. I don't want rust working on the gasket sealing surfaces, or working its way into cemented seams...
  15. jharkin
    jharkin
    Ive never seen any rust... but then again I'm lazy and always put off cleaning it out until the fall. The layer of soot all over the inside of the box probably protects it :picard:
    macpolski and papadave like this.
  16. Firebroad
    Firebroad
    Finksburg, Maryland
    Isn't there a certain amount of oxidation that is causes simply by burning? The inside of my firebox has some reddish dust, even when I am burning. I figured it was no big deal, as long as it wasn't excessive, and there was no pitting or scaling. I do put a big bucket of damp-rid in there in the summer, though.
    Mitch Newton and burndatwood like this.
  17. Certified106
    Certified106
    In The Hills
    I was so happy to shut mine down after last winter that i haven't touched it yet :D
