Wood trap in house foundation suggestion
Discussion in 'The DIY Room' started by J3eLav, Jul 28, 2023.
Tags:
  1. J3eLav
    J3eLav
    canada
    Hi guys,
    I'm building a new house and want to install a trap in the concrete foundation where i can drop my wood directly where it's going to be stacked.
    My cousin has a small door like the attached picture, but i had one quoted and it's 650$ CAD so I'm looking for cheaper options!
    I would definitely appreciate your suggestions!
    Thanks!
    metalcuttr, eatonpcat, Chaz and 2 others like this.
  2. bogieb
    There are several people here that use different methods that don't involve lugging wood or pellets down stairs. Hopefully they can give you soem good ideas.
  3. Warner
    Use the search function for bogydaves set up.
    metalcuttr, Chaz, Screwloose and 3 others like this.
  4. brenndatomu
    It can be a little hard to find...but I came up with it, here...
    Wood chute pictures
  5. don2222
    don2222
    Salem NH
    Hello
    X2 A wood chute or a nice Conveyor belt?
    Nice Wood Stove and register above to bring up the heat Brenndatomu! Is that an All Nighter?
    metalcuttr and J3eLav like this.
  6. Wolley
    Wolley
    If your foundation isn't done and is going to be sticking out of the ground like that, building a door like that shouldn't be a problem. Have the foundation guys leave you the opening you need. Cutting down a solid core door would work.
    Or since we're spending your money add a bump out on the foundation like a you would for bulkhead doors. Make it like 8x8 and instead of a bulk head, frame a room without a floor and doors to the outside so you can dump like 2-3(maybe more) cord in the at once and just leave it right there.
    metalcuttr, J3eLav and brenndatomu like this.
  7. fuelrod
    fuelrod
    Western Maine
    What's your grade going to be where you want this opening?
    In other words is the outside dirt right up to the 1st floor or is it only 1/2 or 3/4 of the basement wall?
    The more bsmt wall showing the easier (cheaper) this gets.
  8. J3eLav
    J3eLav
    canada
    Thanks all for your replies!
    It's flat ground, there should be 3-4 feet sticking above ground.
    It's actually going to be under my concrete patio!
    metalcuttr likes this.
  9. RCBS
    Got basement windows with wells? That's where mine is. Made a simple plywood cover with a hinged door in the middle. On the inside is a 12"x1" wide plank with 2" skirts that can be lowered from a hold point on a joist via small pulley & rope. Gotta bend down to toss the wood in, but it lands 8 feet away from the wood furnace. I know of no simpler way to get wood into a basement. Stacks located just outside where the window well is. I had a grandfather who also used this method. You have a mess to clean up when finished from the pieces landing on the floor, but no big deal...sweep it up and toss into the burner.
    metalcuttr, Chaz and brenndatomu like this.
  10. Warner
    2022 wood migration
    here is my method using scrap 2x’ and a slide I got off Craigslist. It goes up for a weekend or two in the fall then I take it down. If I could do anything different I’d use a slide without the whoop de do.
    J3eLav, wildwest, Chaz and 2 others like this.
  11. Warner
    Or you do this
    J3eLav, metalcuttr, MikeInMa and 4 others like this.
  12. brenndatomu
    That's called the "send it" wood chute! :rofl: :lol:
  13. The Wood Wolverine
    I've been wanting to do that for years.
  14. brenndatomu
    Well get to gettin! :stacker:
    metalcuttr and Chaz like this.
  15. Sandhillbilly
    Sandhillbilly
    North central Nebraska
