Fireview Cat whoops.
Discussion in 'Modern EPA Stoves and Fireplaces' started by Ohio, Jul 25, 2023.
  1. Ohio
    Not Ohio
    Cleaned my fireview cat and I snapped one of the mounting ears. This would be my 4th year with the cat, I think it had at least another decent year in it and another year of diminished performance.
    I already have a spare cat so ill install it this fall. No mistake I perform stove maintenance well before I need the stove.
  2. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Could it be brazed back together or JB welded?
  3. Ohio
    Not Ohio
    I used a craftsman welder this afternoon and it looks not so great but it is more solid than it was originally. Ill keep an eye on it and see if the welds hold up to heat cycling. The one weld is cracked on top but looks better on the underside. I figured if I burned through it or made it worse the cat was already ruined. I'm hoping I get another year out of it.
  4. Backwoods Savage
    Why do you even need to bolt it down? Only when shipping.
  5. brenndatomu
    There's no way JB would take that heat.
    But Dennis bring up a good point, IF that tab even needs to be there, I'd get a welder dude to tig it on...
    Old Nate, Rich L, Screwloose and 5 others like this.
  6. Ohio
    Not Ohio
    The manual says to attach the bolts to secure the combustor to the gasket below. So that's what I did.
  7. billb3
    An oversize washer would have worked in a pinch ?
    Softwood, Ohio, Screwloose and 2 others like this.
  8. Backwoods Savage
    Sadly the manual is not up to date. I stopped bolting it the first time I changed cats. The first cat we had was ceramic but all are steel now.
    Barcroftb, Ohio and Screwloose like this.
  9. Ohio
    Not Ohio
    That was my backup plan.
    I noticed one one of their YouTube videos woodstock said to replace the bolts when done cleaning the cat and the other they didn't. Good to know, thanks Dennis!
  10. Todd
    Todd
    NW WIS
    The old ceramic cats in the cast iron frame was heavy enough that it was not needed to bolt down. The lighter steel cat and frame is much lighter and they state to bolt it down. I bet if there was a back puff it might move it around a bit?
    brenndatomu likes this.
