Plantation firewood production
Discussion in 'The Wood Pile' started by T.Jeff Veal, Oct 25, 2022.
  1. T.Jeff Veal
    After our PA GTG vacation and 4 days of work, we started back to work on my days off. Friday, moved logs and cut rounds... 0623231019.jpg
    Tried a different approach this time, cut the logs in an open area, and used the grapple to pile the round next to the splitter... 0623231018a.jpg
    The bigger rounds, I could pick up 3-4 at once. Worked great. 0623231200_HDR.jpg
    Stacked it Monday morning. That made about 5 1/2 rows in the shed. 0626230905.jpg
    Blue Samson was hungry Monday, so fed him more oak, got a nice pile done before lunch... 0626231403.jpg
    Stacked it Monday evening, that finished the 5th row and started the 6th. Over half way done now. 0626231824.jpg
    metalcuttr, EODDiver, Skier76 and 9 others like this.
  2. eatonpcat
    Perfect stacks as usual!! Nice work
  3. T.Jeff Veal
    Thanks, my friend
  4. Stephiedoll
    Stephiedoll
    Omaha, NE.
    X2, always a work of art. Kind of the opposite of my so called stacks.:rofl: :lol:
  5. T.Jeff Veal
    We finished the big pile of rounds Wednesday. Made it 1/2 way up on the 7th row... 0628232224.jpg
    Cleaned up the area, moved splitter back to shed after a small offsite splitting job. Picked out some of the bigger logs, thick bark that I hope comes off easy, staged them Thursday evening... 0629231616.jpg 0629231616a.jpg
    Cut 6 of the logs into 18" rounds this morning...I know, one of those guys that cuts saw logs into firewood...:picard::picard:...wish Sawdust Man was a bit closer...
    Blue Samson should get fed in the morning. I'm hoping to save this shed for our use, would probably get us on the 10 yr plan...
    metalcuttr, Chaz, WinonaRail and 9 others like this.
  6. Sawdust Man
    Sawdust Man
    Oh that hurts to see such perfect logs going into firewood.....all the while, I'm sawing dinky crooked logs into lumber...
    At least y'all do em justice with your perfect stacks.
    Impressive to say the least!
    metalcuttr, Chaz, WinonaRail and 8 others like this.
  7. T.Jeff Veal
    Thanks, my friend. It was a real blessing to get that job. Cut almost 3 acres, tallest oaks were over 90'. Had some pines in the 80' range.
  8. T.Jeff Veal
    Split and stacked awhile Saturday morning.
    Got lucky when we dropped this oak.
    Glad we were cutting the stumps low, missed the barbed wire fence. 0701231056.jpg
    We made a little dent in the pile, hard to see from this angle though... 0701231120_HDR.jpg
    We stopped before 11:30AM, as I'm on nigjt shift. Got the 7th row finished, good base on the 8th. Set up the big fan and let it blow 24/7 until Monday morning. Almost 100° air dryer... 0701231114.jpg
    metalcuttr, Chaz, WinonaRail and 10 others like this.
  9. The Wood Wolverine
    I've hit barbed wire before and the same high tinsel wire used to train young apple tree limbs. It kills chain, :( you got lucky indeed. :yes:
  10. grandgourmand
    grandgourmand
    Ontario
    I forgot you got that nice Wolfe Ridge. I take it you’re loving it?
  11. Canadian border VT
    So does maple sugar taps:doh:
  12. T.Jeff Veal
    Yes sir. It is a sweet machine, especially when working by myself.
    metalcuttr, Chaz and buZZsaw BRAD like this.
  13. T.Jeff Veal
    Split and stacked a couple hours this morning by myself, Miz Carol had grandsons duty. These big rounds made some nice splits. 0703231124.jpg
    Almost done with 8th row, got 8 more rounds to split. Should be enough to start on the last row... 0703231222_HDR~2.jpg
    metalcuttr, jrider, Chaz and 10 others like this.
  14. T.Jeff Veal
    Got the last 8 rounds split and stacked this morning after getting the ribs on the smoker. Finished the 8th row and started on the last row. 0704231226.jpg
  15. The Wood Wolverine
  16. Stephiedoll
    Stephiedoll
    Omaha, NE.
    A true work of art Jeff. I can only dream having such beautiful stacks.
    How are you liking the X-Cut chain?
    metalcuttr, Chaz, eatonpcat and 3 others like this.
  17. T.Jeff Veal
    Thanks, having great logs makes stacking easy. Got some uglies on top...lol...
    And the X-cut .325 chain is nice. I carried 2 to PA with us. The semi chisel works great on skidded logs. I was able to closely match the factory grind with our Super Jolly grinder when they needed sharpening...cuts great...
    Only complaint I have is it's almost made like a safety chain, the drive link has a hump next to the depth gauge, can't use the progressive file gauge on it. I will have to use regular file guide or grinder if I want to go more than .025 on them.
    metalcuttr, Chaz, Stephiedoll and 2 others like this.
  18. T.Jeff Veal
    Happy to say we finished the oak side of the calico shed today, 9 rows deep.
    Should be about 4.5 cords. I hope when we finish processing all the Plantation wood, somebody can help tally the score... 0705231647.jpg
    metalcuttr, SimonHS, Chaz and 9 others like this.
  19. T.Jeff Veal
  20. The Wood Wolverine
    Love it! Perfect wood size IMO. I got distracted mid vid but I counted 21 splits on that first round. :dex:
    Chaz, metalcuttr, Chvymn99 and 2 others like this.
