New post here, old post elsewhere but enjoy
Discussion in 'Chainsaws and Power Equipment' started by WeldrDave, Oct 10, 2013.
  1. WeldrDave
    This is the log splitter I started construction on and got this far, With some great help from Scotty and a few others, I took some suggestions and did some calculations, I'm going with a 4" ram X 24" an 11 gpm pump and with the horsepower I have should get me about 22 to 27 tons of splitting force +-.
    I now have the pump and the motor bracket "not shown" and I'm building it as my pocket book say's, "and wife too":zip:... I purchased a powerwasher off of craigslist for $75 for the 5hp honda motor, two years old. The dumb a$$ started it up with no water going through it and fried the pump, hence my score! I'm hoping to have it done before Christmas, if not, oh well, I'll slowly stick with it. Enjoy....
  2. Scotty Overkill
    I love it when a project comes together......looking good so far, Dave!
    WeldrDave likes this.
  3. OhioStihl
    OhioStihl
    Southern Ohio
    Nice project and it will have exactly what you want. Good luck with it.
  4. NortheastAl
    NortheastAl
    Putnam County NY
    Yeah, Dave! That is going to be a beast of a splitter. That motor you got looks very clean. Good luck with the rest of the build.
  5. thistle
    thistle
    Polk/Guthrie Counties,IA
    that's a monster
  6. papadave
    Ok, question.
    How is the ram measured? Is it the inner rod, or the outer casing?
    And that's the start of a nice splitter.
  7. DexterDay
    Very nice build. Looking forward to the finished product.
  8. MasterMech
    Ram is measured by the internal bore diameter.
    Also, have you tried assembling the pump to the motor? Power washer engines often have a very short crankshaft compared to a standard engine.
    Are you building a lift for it as well?
  9. rottiman
    Like the height. Should be very comfortable to be standing alongside.
  10. Well Seasoned
    Looking good. can't wait to see the finished product.
  11. WeldrDave
    I thought about it MM, If I can scrounge up the steel I may, I haven't decided on it yet.
  12. Oliver1655
    Oliver1655
    Central Missouri
    Sorry Dave, but a 4" cylinder with a 2,500 psi pressure relief as most log splitter valves are set & tie rod cylinders are rated, will only give you 15.7 tons. HOWEVER - That is sufficient to split most anything you throw at it with a sharp wedge. I have a 4" tie rod cylinder & use a 4 way wedge, (16" tall), most of the time. For real gnarly pieces I will remove the 4 way.
  13. Certified106
    Certified106
    In The Hills
    Looks like it is coming along great! That engine will be very nice!
