Ms170
Discussion in 'Chainsaws and Power Equipment' started by Mykidsdadd, Jun 13, 2023.
  1. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    Bought one last June to have a small saw for limbing. My 193 top handle does good but wanted a little bit more at times but something light. Anyhow, used this thing maybe 3 times and couldn’t keep it running for crap. Took it in, they said bad gas ( same I used in all the others ) and it was good to go. Put it in the shop and went to use it the other day , same problem. Now they are saying low compression?!? I guess my question is , anyone have luck going through Stihl direct for issues? I got the extra warranty when I purchased by buying their fuel or oil or something. I have called twice and left voicemails but nothing. Anyone got a trick or tip ? Should I find another dealer ? These guys are close but rather not trash a brand new saw.
  2. jmb6420
    jmb6420
    Grand lake, Oklahoma
    Find a new dealer. Your warranty is only as good as your dealer and it sounds like the one close to you isn’t interested in taking care of you.
    Mike in Okla
  3. wildwest
    I'm sorry! I'd contact Stihl on angles, phone like you've done, and email, I wonder if there is a Stihl chatboard? Glad you got the extra warranty and not happy you need it!
  4. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    I will look into that too. Didn’t think of that. Will see if the extra warranty means a hill of beans. Lifelong fan of their saws but not much else. Weedeaters are for crap in my opinion. Had a couple and not much better than the craftsman ir box store stuff. Bought a Redmax 5 years ago and still starts like a dream and strong. Bought a new one this year and a leaf blower , they make a good product and are little known here anyway
  5. wildwest
    I would, they have a great reputation, and I think you fell through the cracks. Go Gettem'
  6. FarmerJ
    FarmerJ
    Minnesota
    At least the 180 carb I was able to clean and get working instead of having to replace it.
    makes one a believer in a Holzforma/ farmertec brand saw.. they’re all from China.
    FS45 carb
    MS180 carb…
  7. buZZsaw BRAD
    I bought a 170 new on sale a few years back. Worked well until that Summer when it wouldnt hot start. Id leave it idling and muffler got clogged with carbon. Dealer cleaned for free even though it wasnt covered under warranty. I had enough and sold it to Eric Wanderweg. The only Stihl saw ive owned that i didnt like. It was replaced with a 201 rear handle.
    Be persistent with Stihl. A new saw shouldnt give you issues. Consider upgrading to a 192/193/194 rear handle. Roughly same weight as a 170.
    I own a couple top handles as well so know what you are saying about the rear handle.
  8. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    Guess I didn’t realize the 19o series had read handle ?! I will definitely look in to it.
    Disappointed in this saw to say the least. Hopefully they will make it right , all my others are and ale have been bulletproof
  9. Eric Wanderweg
    My MS170 has been temperamental for sure. It was running decent in the cooler weather, but now it’s acting up. It’s fine if I’m on the throttle hard taking heavy cuts, but if I’m using it sporadically taking it easy it starts to bog down and almost fouls the spark plug. Gotta keep goosing the throttle to clean it out. I use it infrequently so I’d rather not try to tune it for the hot weather, then tune it again in the winter.
  10. The Wood Wolverine
    If it's under warranty, hound your dealer. If you don't use it frequently, used canned E-free fuel.
  11. buzz-saw
    buzz-saw
    Ct.
    I have one and zero issues , I used it this past weekend. Bought mine in 2013
    E free fuel in all my saws.
  12. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    Same , e free on all small engines at my place for sure. Mower, saws ,atv , anything.
    Got a hold of Stihl. They called dealer and I am taking it back to them tomorrow and they will diagnose and decide to repair or replace. To be continued!
  13. buZZsaw BRAD
  14. Eggshooterist
    Eggshooterist
    Erff
    They have a rear handle 151 too.
  15. Mykidsdadd
    Mykidsdadd
    NE Oklahoma
    do they start like other saws or like the 192/93t? So use to choke until it tries, half choke and pull once or twice the to run. The top handles I own have a different process to start and isn’t as easy in my opinion.
  16. buZZsaw BRAD
    241 takes precedence in my current CAD . If you ever get one ill never hear the end of it.:picard:
    Ive seen a some 150/151 top handles for sale around here but dont think ive seen a rear handle.
  17. Eggshooterist
    Eggshooterist
    Erff
    Ummmm. I have a 241.... and you, well.....ya don't. Lol
  18. buZZsaw BRAD
    Had to check. The 192 RH was bought cheap as it was seized??? and hasnt been fixed.
    My 194 & 201 top handles. The 194 has a primer bulb. 201 has mtronic carb and no primer. I wasnt planning on getting the 201 but it came up for sale, ironically a week after i got the 201 rear handle, for a song and a dance and i couldnt say no. IMG_3420.JPG
  19. buZZsaw BRAD
    201's. Both mtronic carbs. The rear handle has a primer bulb??? IMG_3421.JPG
  20. Eggshooterist
    Eggshooterist
    Erff
