Splitter moves much more better!
Discussion in 'Chainsaws and Power Equipment' started by WeldrDave, May 25, 2023.
  1. WeldrDave
    My Splitter is 675 lbs and it's really becoming a B!T@H to move around anymore. I removed the factory dog leg up front and bolted on a swivel trailer wheel rated for 1000 lbs.
    As much as I don't like Harbor Freight because of the Chinese connection, I got a complete set up for $34.99. :yes: The old dog leg came off with a snap ring pliers and there was an existing plate in place. Clamped it to it and bolted it up. If it comes loose I'll throw a couple 1" welds top and bottom. I did cut the bolts shorter, I could see some flesh coming off my legs if I left them long. It flips up right into the spot the old one went to.
    It now rolls much more better:D:cool:
  2. Dok440
    Dok440
    NorCal
    Nice! I have that same splitter and have been thinking about doing the same. I like the adjustable height. I'm often on uneven ground and that would allow me to level the splitter in that direction. Does it feel secure enough with the clamp?
  3. Warner
  4. WeldrDave
    So far so good! I split mostly on the street or cement so this will work for me. Lifting this thing was killing my back! :( The dog leg is held on with s snap ring, you gotta look close but you'll find it. This fit right over the plate. If you need more pics, let me know, I'll get some close up ones.:yes:
  5. WeldrDave
    Mine came off after about a year or so. Yard max didn't even answer me back when I sent them an e-mail. Chinese paint job! :headbang::hair: Oh well, I'll clean it up when I'm free and throw some primer on it.
  6. Warner
    I used POR15 it’s held on for 10 ish years.
  7. MAF143
    MAF143
    North Central OH
    The green cooler with adult beverages makes all the difference!!!
    A hot sunny day working on MANLY stuff requires priorities be kept in place!!!
  8. WeldrDave
    Also works well as a comfy seat! ;)
  9. Stephiedoll
    Stephiedoll
    Omaha, NE.
    The new 30-ton is a pain to move around as well, but no pavement here. Thought about one of the trailer dollies that I see around but more Chinese junk.
    In the Pines, FarmerJ, RCBS and 7 others like this.
  10. buZZsaw BRAD
    Nice job Dave! Some FHC engineering there. Not a fan of moving the splitter myself, neither is my hernia!
    Learned a valuable lesson when using the ball hitch on my PU to move the splitter. ALWAYS make sure the "kick stand" is down when you go to set the splitter in place. Dropped on my finger! :eek:
  11. theburtman
    theburtman
    I have a ball hitch on my Cub Cadet for moving the splitter
  12. WeldrDave
  13. WeldrDave
    I have one on my ATV but not much room to move around on 1/4 of an acre... :rofl: :lol:
  14. buZZsaw BRAD
  15. WeldrDave
    Thanks Brad, I don't have to move far, and all on asphalt or cement. It's such a PITA picking the end up to go 75ft. Yeah, I feel it in my back and guts also, I know the feeling. If I was on all dirt or on my land up north, I would have left the dog leg.
  16. WeldrDave
    It was thought of... :whistle:
  17. Chris F
    Chris F
    Micksburg, Ontario
    That's one of the first things I changed on my splitter. Makes moving it around in the garage much easier.
    I can still lift it onto the ball on my lawn tractor but the day will come when that becomes too much.
  18. Elm-er Fudd
    Elm-er Fudd
    Kansas
    I have the county line 25 ton with the weird kickstand thing on the front. Going to cut it off and put one on like you did. Harbor Freight has them on sale this weekend for $29.99
  19. WeldrDave
    You'll find, you wish you did it sooner! :yes: My splitter is 5 years old and I should have done it right after I got it. o_O
  20. WeldrDave
    After looking at the bolt on set up, it'll be fine but, I am going to make a plate out of 1/4" the size of the swivel plate, mark out the 4 holes where the bolts are and weld it to the existing plate on the splitter. It'll be stronger and take more abuse.
    I'll update the tread and progress next week after Memorial day weekend.:) :usa:
