Bark fires?
Discussion in 'The Wood Pile' started by CutSplitStack, May 13, 2023.
  1. CutSplitStack
    CutSplitStack
    Hey everybody, so I've been doing a lot of bark fires on the patio this spring. They're nice sometimes because a) they light quick b) they burn out quick so if you only have time for a short one it doesn't feel wasteful like when you light up nice wood and c) it gives me a way to get rid of all the splitting scraps. Anybody else do this?
  2. BuckeyeFootball
    BuckeyeFootball
    Ive had several bonfires this year so far that were mostly bark piles from splitting. Ive also got a tote of bark for kindling.
  3. Backwoods Savage
    Some folks burn it in their stoves and you will get heat, but you also will get a huge amount of ash for a little amount of heat. If you are short on the woodpile, go ahead.
    Cash Larue, Ron T, RCBS and 5 others like this.
  4. Skier76
    Skier76
    CT and SoVT
    Bark puts out a decent amount of heat. I’ve tossed a bunch in the stove before and the temp shot up.
  5. buZZsaw BRAD
    If its decent and not punky etc. ill put it aside for the firepit. Depends on the species too. Black locust bark stinks when burned so that gets returned to the earth. Lots of it ends up around the stacks/processing area for mud control.
  6. Fanatical1
    Fanatical1
    I use bark on occasion as kindling… works great to get a fire going. I only keep the nice bark slabs, not a bunch of trash, that bark stays in the woods.
  7. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    I burned a bunch of bark up last week. Still got a bunch from cleaning up around the empty stacks, I’ll use it for fire pit kindling until it’s gone.
  8. RCBS
    I had a lot of oak that shed it's bark while working it up this winter. I intially started using it as a top cover, but then switched to using it as 'flooring' for the stacks. Makes an excellent base layer to stack on top of if you are not putting on skids. I have used it in the past to cover muddy areas around the wood pile.
  9. RGrant
    RGrant
    Connecticut
    Waste not, want not.
    Used bark this weekend in the fire pit for the Mother's Day grill out in the yard.
  10. JDU
    JDU
    Perry County, PA
    Like to burn bark in the fire pit. Depending on species, really ads to smoke smell too.
    FarmerJ, Cash Larue and buZZsaw BRAD like this.
  11. buzz-saw
    buzz-saw
    Ct.
    Most of the bark from my splitting goes to the stump-dump.
    Falls off when splitting it gets trashed , if it stays on the split it then gets burned.
    I have a lot of larger quarters of Oak that has been sitting for a year or two , most of that falls right off and leaves me with all barkless splits. The bark is kind of wet and nasty so to the dump it goes.
  12. Timberdog
    Timberdog
    Az
    I bought a gas powered mulcher for bark and splitter scraps. Bark also makes great mulch for my trees, garden, and compost pile.
  13. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    I get a fair amount of shagbark and always save it. Burns great:D
    Cash Larue and MAF143 like this.
  14. stuckinthemuck
    stuckinthemuck
    I stopped burning bark that falls off. I have run some through the chipper/shredder to help break it down for the compost pile. I also just dump piles of it in the woods. Fungi take it over to slowly extract nutrients to supply to the trees and it makes for a great moist micro environment for frogs, toads, salamanders and newts..
  15. Cash Larue
    Cash Larue
    Pine, CO
    I burn a lot of bark in my solo stove, outdoors. But I also burn a fair amount of bark in my wood stoves. It burns great! I have tons of firewood split, stacked and seasoned. But I get satisfaction out of burning bark. Plus, I enjoy feeding the fire and don’t mind cleaning out ashes - especially during shoulder season (June, July and August).
