Typical for big black locust?
Discussion in 'The Wood Pile' started by jrider, May 8, 2023.
  1. jrider
    jrider
    This is the biggest black locust I’ve come across. To those who have more experience with it than me, is this typical for them when they get big? You can see the parts that rotted and were broken down to an almost soil like material. Biggest log was about 38” in diameter. Tough on a chain as you could imagine.
    075060DB-2C64-402D-A514-274DAA2EF052.jpeg C2A22C30-021A-43E7-BBE6-69DB92F5D560.jpeg F57C0D52-36AD-4A86-8954-44D8B569BBC3.jpeg
  2. Eric Wanderweg
    Yep. Bark inclusions and locust borers are like cancer to the heartwood.
  3. Eric VW
    Yep. Concur, sameness in naming. :handshake:
    Rich soil look, ginormous grubs (depending on calendar).
  4. B.Brown
    B.Brown
    USA
    All the above, plus people tend to drive a far share of nails, tacks, and staples in that size as well!
  5. The Wood Wolverine
    Mark that stack for personal use only. No sellin’. :dex:
  6. jrider
    jrider
    No metal thankfully
  7. jrider
    jrider
    Plenty of clean wood if split properly but there will be more headed to the owb than I’d like.
  8. The Wood Wolverine
    Sometimes ya gotta take the good with the bad. I’ve been there plenty. Like dad always says.. “it’ll burn”. :fire:
  9. buZZsaw BRAD
    IME yes. I cut a load in January of last year like that. More of a PITA than what it was worth. Cant mix too much cull stuff in BL cordage. IMG_0106.JPG
  10. buZZsaw BRAD
    Sandhillbilly, jrider, RCBS and 5 others like this.
  11. jo191145
    Usually unless a large amount of ants have lived in it there’s very little rot besides the bark inclusions. Yeah it looks bad at first. Split it and toss it in the pile. The sun and rain will clean it up quick enough.
  12. Hickorynut
    Hickorynut
    Owensboro, Ky.
  13. Hickorynut
    Hickorynut
    Owensboro, Ky.
    This is the way most of it is around here but locust is my most burned and a favorite!! I peel the bark too, if the sap is running it pops off pretty easy!!
  14. Biddleman
    Biddleman
    River Hills of Pennsylvania
    When I come across a really large BL log I usually count on some part being rotten out like that. One thing is never give up when you come across a rotten section, because it can be rock solid 2" inches from that part.
    Just as jo191145 said, dry it out and it's good to go.
  15. The Wood Wolverine
    I cut up a nice size BL once and it had a very small amount of soft in the center. You can see the base piece on the right in this pic. I did not go up far at all.
  16. jrider
    jrider
    Ended up with two bins of waste. Was able to salvage the rest.
    eatonpcat and buZZsaw BRAD like this.
  17. buZZsaw BRAD
    What criteria do you use for "waste"? I stacked some bark on BL and three wheelbarrow fulls probably wouldve gone in those bins.
    eatonpcat likes this.
  18. jrider
    jrider
    Needs to be wood. No bark. No tiny scraps.
