Stihl Parts :(
Discussion in 'Chainsaws and Power Equipment' started by jo191145, Apr 21, 2023.
  1. jo191145
    Anyone know a place I could buy a bar stud for a MS 462? I’m just realizing Stihl doesn’t allow parts to be sold on the internet. Not a happy camper. Stihl dealers say it could take weeks to get one in.
    Screwloose likes this.
  2. Eric Wanderweg
  3. JimBear
    JimBear
    If Eric can’t hook you up, I believe I might have a couple.
  4. RGrant
    RGrant
    Connecticut
    STIHL MS Bar Stud - Chainsaw Parts World
  5. JimBear
    JimBear
    I will bookmark that site but it lists the 440 also.
    The studs in my 440 are different than the ones in my 462 but the pictured studs do work on the 440 cover. Iirc the original studs had a flat face not the tapered face coming into the threads.
    The local dealer told me the taper was to accommodate the captive bar nuts on the cover.
  6. jo191145
    Yes I saw that and at least one other place. That one seems to be in New Zealand and others in the UK. Don’t think I didn’t debate calling them and ask for it to be overnighted hahaha
    I’m not even finding used ones on eBay.
    Screwloose and brenndatomu like this.
  7. jo191145
    So I pulled the stud. Things look worse than I had hoped. Not sure if anyone would attempt to helicoil that? I’ve never done the process myself but the cracking of the magnesium is probably a red flag. What say you all?
    May need a new crankcase instead of a repair.
    Anyone know a good Stihl mechanic? In the New England area might be nice :) Stihl dealers in my area dont exactly cause me to exude confidence. They’re sellers not mechanics.
    Maybe best to send it away to get ported and repaired at the same time? Anyone interested in a job? :)
  8. JimBear
    JimBear
    I can’t like that post. That gives me the sads.
  9. jo191145
    The best life lessons are the expensive ones :)
  10. Skier76
    Skier76
    CT and SoVT
    That’s a bummer! Any idea what caused that?
    farmer steve and jo191145 like this.
  11. jo191145
    oh absolutely. Cutting a leaner with another leaner on top of it. First cut I hit buried barbed wire. Moved up the trunk a little and pinched the bar. Grabbed another saw and cut above the 462. At that point the tree reversed barber chaired. It split in between the last two cuts dropping the tree and saw on my foot. In reality it was some stupid flustered moves on my part. One of those days where the powers that be tell you to pack up your gear, go home and try again when you get your ducks in a row. I did :)
    Trees I’m cutting right now aren’t that big so I began using my 550. Was a week later I decided to pull the chain off the 462 to sharpen it from the wire contact. It was then I noticed half the clutch cover missing. doh I had thought only my pride and foot had been hurt.
  12. Jeffrey Svoboda
    Jeffrey Svoboda
    Maybe some jb weld with the new bar stud might keep you from replacing the case?
  13. Woodpusherpro
    Woodpusherpro
    East of Dallas, Texas
    Well.. how is your foot?
  14. In the Pines
    In the Pines
    If I was to go the jb weld route, I would use loctite retaining compound 660. I used it on a 288 with a bum bar stud and it worked very well for it.
    I don't have that saw anymore but I never heard anything back from the member here about it.
  15. buZZsaw BRAD
    There are a few in my area but wouldnt recommend for repairs. How did you do that Joe?
    Need a loaner 462 till its fixed?
    brenndatomu and jo191145 like this.
  16. jo191145
    That was my first hope. Still going to attempt it but have less hope. Have a few tricks up my sleeve but if none of the hole is still concentric I think it’s a lost cause. We shall see.
    brenndatomu and buZZsaw BRAD like this.
  17. jo191145
    Well it wasn’t all that good of a foot before the tree/saw fell on it so I was lucky in that aspect :) Guessing one or two fractured metatarsals but I was out cutting down some small tree of heaven later that afternoon. That foot doesn’t feel much pain anymore.
  18. jo191145
    I’ll look into that. Thanks.
  19. jo191145
    Appreciate the offer but the two 550’s will pick up the slack for now. Only a few large trees kicking around and they can wait.
  20. buZZsaw BRAD
    Was this the saw that landed on your foot?
