Ultrasonic cleaner juice
Discussion in 'Chainsaws and Power Equipment' started by Backwoods Fellin', Apr 9, 2023.
  1. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    I have used the Lyman brass cleaner for years and seem it is about time to change it as it now seems to leave a layer of slime on my chains. What have ya'll found to be the best OTC or homemade solution for your tanks?
  2. jo191145
    I’ve never done chains. Experimented with rifle brass for awhile. Think I used white vinegar and water 50/50. For chains some blue dawn dish detergent would help break down the oil too.
    Screwloose and T.Jeff Veal like this.
  3. Meche_03
    Meche_03
    Missouri
    For chainsaw chain I've used water with Dawn soap and generic parts cleaner degreaser that doesn't fume/off gas.
  4. BuckeyeFootball
    BuckeyeFootball
    Were supposed to clean our chains?
    Screwloose, RCBS and T.Jeff Veal like this.
  5. Eggshooterist
    Eggshooterist
    Erff
    And the saw. Like remove all the bodywork to do so type cleaning...
  6. jo191145
    Ready for degreasing.
  7. Eggshooterist
    Eggshooterist
    Erff
  8. Eggshooterist
    Eggshooterist
    Erff
  9. jo191145
    Filthy. Doesn’t seem to effect performance tho :)
  10. Eggshooterist
    Eggshooterist
    Erff
    Certainly not....but my OCD, that gets affected. :loco: :crazy:
  11. RCBS
    Lemishine is popular for cleaning firearms stuff. I've used it before with stainless media in a tumbler. You'll try anything to get the crud out of a .22lr suppressor. Learned to dip them in synthetic brake fluid after cleaning to keep it from sticking so badly.
    Screwloose and jo191145 like this.
  12. corncob
    corncob
    Somewhere in Lower Michigan
    Looks like the Stihl arborist top handle saw I ran over with my tractor a few months back. it went to the landfill. 700 clams down the tirlet real quick.
  13. corncob
    corncob
    Prior to grinding. The gunk on a loop will foul the grinding stone.
  14. The Wood Wolverine
    I soak my milling chains in either Purple Power or Simple Green. Both work great but I've never used an ultrasonic. Quick swipe with a brush in the sink and a rinse w/ hot water and they come clean very easily.
  15. buzz-saw
    buzz-saw
    Ct.
    I use Simple Green myself.
    Work buys it in bulk so lets say my cost is minimal.:yes:
  16. Backwoods Fellin'
    Backwoods Fellin'
    Nashville TN
    Screwloose likes this.
  17. corncob
    corncob
    If I'm really in a hurry, I'll use aerosol brake cleaner on a loop. I do prefer a soak in the ultrasonic cleaner however but that takes time.
    Screwloose and Backwoods Fellin' like this.
  18. Meche_03
    Meche_03
    Missouri
    I don't usually clean my chains. I got 2 gallons of once used chains onetime and I needed to clean them up as I sorted them out and some of those chains clearly ran on used oil or vegetable oils, not bar oil.
    It was a lot of work but for $25 I got chain for years. Soaking in a bucket with simple green for a few days doesn't take much time.
    After the chains are all clean and sharpened I soak them or ultrasonic them in bar oil then let them drip dry back into the soak. I want to get new oil back into the chain internals before flash rust takes over.
  19. Reloader
    Reloader
    NW Oregon
    I’ve never done chains but Simple Green and water work well for cleaning the small engine carbs.
