40:1\50:1?
Discussion in 'Chainsaws and Power Equipment' started by Theashhole, Mar 27, 2023.
  1. Theashhole
    Theashhole
    Osceola, In
    Anyone else use this? I'm a bit confused on what it's mixed to, maybe it's 45:1 and can be used in both?
    Hope it doesn't tell me the info I'm looking for on the back of the can cause I don't feel like going back out to the barn to look :D
  2. Chud
    Chud
    It appears it identifies with both ratios :rofl: :lol:
    NYH1, metalcuttr, huskihl and 15 others like this.
  3. MikeInMa
    Non-binary mix. :whistle:
    NYH1, metalcuttr, Stinny and 11 others like this.
  4. Theashhole
    Theashhole
    Osceola, In
    :picard:ay yi yi :wacky:
    NYH1, metalcuttr, Ron T and 5 others like this.
  5. Eric Wanderweg
    Too lean for the die hard 40:1 guys, too rich for the 50:1 zealots.
    NYH1, metalcuttr, KSPlainsman and 5 others like this.
  6. Farmchuck
    Farmchuck
    Nepa
    Maybe it’s 45:1?
    NYH1, metalcuttr and eatonpcat like this.
  7. FarmerJ
    FarmerJ
    Minnesota
    I think you'd be better off talking about politics or religion.
    Mrxlh, NYH1, metalcuttr and 10 others like this.
  8. JD Guy
    JD Guy
    Upstate SC
    :thumbs::rofl: :lol::rofl: :lol:
    NYH1, metalcuttr, MasterMech and 5 others like this.
  9. The Wood Wolverine
    Not even remotely close.
  10. Eric VW
    Tongue in cheek.
    NYH1, metalcuttr, Ron T and 1 other person like this.
  11. brenndatomu
    Its 50:1 at 60hz and 40:1 at 50hz...duh.
    Mrxlh, ThomH123, GMB77 and 15 others like this.
  12. Eric VW
    Your posts are funny with great frequency. :whistle:
    :D
    GMB77, NYH1, metalcuttr and 15 others like this.
  13. Theashhole
    Theashhole
    Osceola, In
    Least I made a fun post!
    I'll run it and see how the 372 likes it!
    NYH1, metalcuttr, Eric VW and 4 others like this.
  14. isaaccarlson
    isaaccarlson
    Colfax, WI
    It's most likely 50:1. My little oil bottles say "replaces 25, 32, and 50:1" but it's only enough oil for 50:1.
  15. RCBS
    Recent 40:1 adopter here. :saw:
    I made some of this 40/50 myself a couple weeks ago by adding some canned Husky fuel to a saw with 40:1 red armor already in it.
    NYH1, metalcuttr and Farmchuck like this.
  16. FarmerJ
    FarmerJ
    Minnesota
    I carry a 5 and 1 gal can of gas. I keep a 6-pack of small bottles in the field box for that same 6 gallons of gas. I refill the bottles at home out of a larger container that’s more cost sensible.
    kind of convenient that way.
    RCBS, NYH1, isaaccarlson and 3 others like this.
  17. billb3
    If it's bi you must buy.
    50:1 is supposedly a good ratio for an average user cutting an average amount of firewood, but if I was milling or cutting huge trees with a huge saw I'd probably go a little heavy on the mix. I buy those little expensive Stihl one gallon nip size bottles of oil and and stay shy of a whole gallon of gas.
    I'm not cutting as much as I used to either.
    Maybe it's a synthetic oil that has a "range of lubricity". LOL
  18. stuckinthemuck
    stuckinthemuck
    As I understand it, the mix ratio is dependent on the equipment and the quality of the two cycle oil that is used.. A better quality oil can be mixed at a higher ratio while a lesser quality oil needs a lower ratio. I would guess that the actual ratio in the bottle is 50:1 but the mix has been tested to be adequate for engines that require 40:1.. Of course this is probably more about a clean burn and EPA regulations than it is about long engine life, so I'd be careful using it with equipment that requires a ratio more rich than 50:1.
    isaaccarlson likes this.
