The 2023 march
Discussion in 'The Wood Pile' started by jrider, Jan 7, 2023.
  1. jrider
    jrider
    It’s a bright sunny day but I only cut for an hour because it was muddy and I didn’t want to turn it into a sloppy mess.
    86893D0B-D1C6-43CF-9BAF-49B6E72EBAD4.jpeg CFDE2485-23B3-48E2-A41B-D82827FC52CE.jpeg 94C593AC-E206-4ED8-B576-6C53C24F4BAA.jpeg
  2. jrider
    jrider
    Since I quit cutting early my son and I finished up splitting oak for his roadside stand. Between these two piles there’s about 12-14 cords. Now he has some stacking to do!
    Im hoping to be able to make this pile of logs disappear by the end of next weekend. Will need some dry weather though.
    8A089B60-7A6B-4DE6-AA39-99293BE6942F.jpeg D0FBD6FC-AC42-446B-B635-3C1D7B7F42A7.jpeg 6B001CFA-C36C-4309-A9AD-288EDFEE604B.jpeg 34000855-9DB4-4B34-8CD4-3FF9215A2C83.jpeg
  3. buZZsaw BRAD
    Mud isnt fun. Cant blame you there. You are the log mover and bucker correct? Helpers do the splitting?
  4. brenndatomu
    You know it was too wet to work when you come home and she calls you a dirty mudder bucker...:whistle:
  5. T.Jeff Veal
    I know pile smells good, baking in the sun
  6. T.Jeff Veal
    Just caught up with your new thread. Looking mighty good up there.
  7. buZZsaw BRAD
    :rofl: :lol: :thumbs:
  8. jrider
    jrider
    Yes correct. I split some but they do the bulk of it these days
  9. jrider
    jrider
    Had two good afternoons this week to work. Got the messy pile of logs cleaned up.
    Almost done this oak pile. It will measure about 115’ long. Did hit metal on a cut Wednesday. Not that hitting metal is ever a good thing but at least this chain was almost dull enough to take off the bar and exchange it for a freshie.
    Will need to get a lot more logs in here if I’m going to have anything to process come summer.
    6DAAD3EF-B241-4D69-9398-BC7E0388A5D9.jpeg 81FE0905-D414-4A49-BC93-F7F40602F1F5.jpeg 9E33F803-982C-4634-8781-5C145E22C3CC.jpeg EC92A060-AEEF-4655-8D67-521DA5593E57.jpeg E0403024-4906-4D09-9275-24135A5A9E0B.jpeg 64A25246-8CB8-4271-B758-E397AF04CBF0.jpeg
  10. buZZsaw BRAD
    Making good progress and the nice weather helps for sure.
    How often you hit metal Joe?
    amateur cutter and T.Jeff Veal like this.
  11. jrider
    jrider
    I must hit metal 6-8 times a year
  12. T.Jeff Veal
    For mostly yard trees, that's not bad at all. Especially with as much as you cut.
  13. jrider
    jrider
    Quite a bit of it is visible and because I pick the logs up with forks, it usually rolls around enough for me to see the obvious
  14. amateur cutter
    Looking good Joe! My log inventory is about 25 cord. About 30 cord split. Been mud here for weeks. I bought three lead loads from a farmer that is clearing ground. Cherry and Hickory run through a processor. Couldn't get in the woods all winter. No frost in the ground. 20230324_153008.jpg
  15. T.Jeff Veal
    Nice
  16. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Now that is what I call a dump trailer. How many cords to fill it?
  17. amateur cutter
    Holds 7 cord. Makes for a nice load.
    Chaz, brenndatomu, Chvymn99 and 4 others like this.
  18. jrider
    jrider
    What’s he charge?
  19. amateur cutter
    $850.00 per load. Can't really go wrong for that.
    Chaz, eatonpcat, brenndatomu and 6 others like this.
  20. jrider
    jrider
    I'd buy every stick of wood he can make at that price.
    Chaz, Chvymn99, eatonpcat and 4 others like this.
