Echo CS top handle Arborist Saw
Discussion in 'Chainsaws and Power Equipment' started by corncob, Mar 24, 2023.
  1. corncob
    corncob
    Somewhere in Lower Michigan
    Replaced my smashed Stihl top handle, wasn't about to pay another 700 bucks for one... Nice and very light saw (7 pounds loaded) Plenty of suds with one glaring exception, it comes with a cat in the muffler which I had to replace with a non cat muffler (Echo offers non cat mufflers as an accessory)
    Like the adjustable bar oiler as well as the roller nose (greaseable) bar and ships with an Oregon low pro chain. Quite a bargain at 335 bucks versus the 700 Stihl.
    Power wise it's about the same as the Stihl but a lot lighter and the I30 starting system makes starting a breeze.
    Finally, the Echo has a 5 year consumer warranty on it (1 year professional use), all in all, a good buy.
    Stephiedoll likes this.
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    Which "cs" are you talking about. A quick web search pulls up 3 or 4.
    JD Guy likes this.
  3. JD Guy
    JD Guy
    Upstate SC
    Which model is it? Thanks!
  4. RCBS
    I'm guessing 271.
    JD Guy likes this.
  5. corncob
    corncob
    Echo only makes 2 top handle arborists saws and I bought the less expensive one. Only difference I can find is the more expensive one has a metal lanyard ring while mine is molded into the back of the lower air cleaner body. It's a nice and pretty powerful saw, actually has more balls than the Stihl I ran over a while back and broke the crankcase on. Sadly, that went to the landfill.
    Getting ready to buy another, larger rear handled one and sell my modded MS that has very low hours on it. I'll sell it with 2 loops of 325 chipper plus an extra roller nose bar and of course the loops will be very sharp. Did the muffler mod on the MS and re jetted it as well.
    Much more economical than a Stihl or even a Husky for that matter.
  6. Eggshooterist
    Eggshooterist
    Erff
    I'm pretty sure Echo make 4 gas top handle saws and one battery version.
    The CS-2511, CS-271, CS-303 and CS-355 are the gas units.
    Jeffrey Svoboda and eatonpcat like this.
  7. corncob
    corncob
    Far as I can ascertain, they only offer 2 top handle Arborists saws. The one I purchased and the other more expensive model. I have switched all my saws over to synthetic fuel with excellent results. I'm using the pre mixed Red Armor fuel now. I don't do battery powered saws at all and never will. Only battery powered stuff I have are a flashlight and a couple HF 20 volt tools.
  8. Jeffrey Svoboda
    Jeffrey Svoboda
    Well maybe you should ascertain just a little bit more cause Eggshooterist listed all 4-5 in the post above yours.
    What's so hard about posting the model number of your saw? You keep jumping around the question like you can't remember and don't want to admit it.
    RichE23ACR, Eggshooterist and JD Guy like this.
  9. jtakeman
    corncob It would be out of courtesy that posting the model of said saw be recommended in reviews!
    I too see 4 models on Echo's web site.
  10. Jeffrey Svoboda
    Jeffrey Svoboda
    Well those can't be it.... they don't say "Arborists" anywhere on the description. :emb:
  11. Eggshooterist
    Eggshooterist
    Erff
    Top handle saws ARE arborist saws are they not?
    RichE23ACR and Jeffrey Svoboda like this.
  12. corncob
    corncob
    CS 271T, how's that 12 " bar and loop. Also comes with a 14 but 12 is good with me.
