Multiple Use Items
Discussion in 'Everything Else (off topic)' started by HoneyFuzz, Feb 5, 2023.
  1. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    So what items do you use...that you use for a purpose other than the one that it was intended to be used for ?
    Made me think today..as my tractor with backblade ..was in the barn. Makes a handy place to tap the ice out of the rabbit water bowls on these cold days !
  2. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Used my fiskars hookaroon as an ice pick today to get an extension cord dug out that was running Christmas lights
    metalcuttr, JimBear, wildwest and 6 others like this.
  3. Sandhillbilly
    Sandhillbilly
    Today’s shoe laces suck. The outer cover wears out and slides up the core. I thought I’d see if this would work better. It’s a little stiff for tying the knots but it’s holding up pretty good. D3D19270-11A1-4376-81FD-72E0C0345B81.jpeg 13C44CA5-1F7B-4AB2-9DD5-7A5D2AB96530.jpeg
  4. buzz-saw
    buzz-saw
    Ct.
    Screwdriver; also used as a chisel or prybar.
  5. RCBS
    Nice. I used to have a picture of a buddy's boot that was laced with blue zip ties in a pinch.
    I am also a lace breaker. I found these a few years back. Your shoes will wear out before the laces ever do (true story, transferred them to a new pair lol).
    Boot Laces | Tough Long-Lasting Boot Laces by Kg's Boot Guard
  6. billb3
    I use STP oil treatment instead of white lube anywhere you might use white lube. Lasts at least ten times longer on sleeve bearings.
    I'll use electrical tape to help keep a bandaid on. Usually a finger.
    metalcuttr and theburtman like this.
  7. Warner
    Superglue is good for keeping a slice together.
  8. lukem
    Super glue and dental floss can keep about anything closed up.
    metalcuttr, eatonpcat and theburtman like this.
