Help Identify
Discussion in 'Everything Else (off topic)' started by Brady Picklesimer, Feb 26, 2023.
  1. Brady Picklesimer
    Brady Picklesimer
    Found this in the middle of some old woods, rural eastern Ohio. The timber was cut some time ago, maybe 50/60 years. Looks like a piece off old machinery. Starts off 1-1/4” round, turns 4 sided with a 1/2” hole halfway down, then flattens out to paddle shape. Serious pitting of material. Been there a long time. Any ideas of what this may be? Thanks.
  2. MikeInMa
    Nice find!
    Looks heavy. Rock bar heavy?
    As it looks like a spoon without a sharpened edge, maybe it was used to remove bark?
    Maybe used to stir moonshine mash?
    Guessing a cord through the hole to hang it?
    The hole
  3. billb3
    Jaffa plasma cannon.
  4. Backwoods Savage
  5. Brady Picklesimer
    Brady Picklesimer
    Replaceable tip. Zoom in on the pic with v notch. There’s a screw head in it.
    I’d say the sucker is 20lbs. Carried it a mile out so it was heavy enough.
  6. wildwest
  7. billb3
  8. wildwest
  9. walt
    walt
    north central ohio
    Could be a blacksmith made bark spud
  10. wildwest
    what might the bolt hole in the middle be for? Attach a handle?
    Backwoods Savage and walt like this.
  11. billb3
    Stargate TV show from a while ago. I cut the cord on cable and broadcast TV quite a while ago so I can be a bit behind the times when it comes to those venues.
  12. Brady Picklesimer
    Brady Picklesimer
    That is what I am leaning to so far. It almost looks like the spade end has been welded together.
  13. Chud
    Chud
    It looks like a tooth from a pull behind tractor implement my grandpa called a chisel.
  14. Brady Picklesimer
    Brady Picklesimer
    Did they slide up in a 1-1/2” sleeve and lock with a pin?
  15. Chud
    Chud
    Too long ago to remember how they attached and the farm is 1300 miles away, so I can’t stop by to see if it’s still at the farm. They would have been replaceable if damaged.
  16. Chud
    Chud
    I googled it and it comes up as chisel plow, so you can compare it to the blades on one.
  17. Wolley
    Wolley
    Looks like a homemade pry bar for moving heavy things around. I bet it still works.
  18. Eric VW
    Welcome aboard Brady Picklesimer :handshake:
  19. Eckie
    Eckie
    My father in law has something very similar (maybe just a tad shorter) that he uses when removing tires from a rim, or putting them on. Not sure if that's what it's made for, or if he just uses it for that task
