CL. Make your own pellets?
Discussion in 'The Pellet Bag' started by savemoney, Sep 4, 2014.
  1. savemoney
  2. will711
    will711
    Pocono Mts.
    I don't know if it works or not ,but for the $ 2295 price you can buy tons of pellets, :thumbs: A whole lot easier and better quality.
    savemoney, imacman, ttdberg and 2 others like this.
  3. imacman
    imacman
    Denver, NC
    These have been discussed many times at that "other" website.
    After the $$ for the unit, the power source to run it (see pic of driveshaft in your post), and then securing a large supply of sawdust, then add in the fuel for the power source, your time, and the fact that it makes pellets pretty slowly compared to a large commercial unit, the consensus was that it was not viable. As will711 mentions above, for $2295 + $ for power source, etc, etc, .....well, you get it.
    savemoney, will711 and ttdberg like this.
  4. nate
    nate Banned
    Palmer, AK
    I have a TON of sawdust, well more like several tons. My bin is 4x8 x4ft tall and I fill that every couple days.
  5. chris
    Nate,I your case it might be viable, but wood pellet units require a double reduction gear drive( that pic isn't) particle size 6mm max( 1/4") moisture content 8% max, I do not know what effect mdf and plywood sawdust would have on production. I have a bunch more info pm if you want.
  6. jtakeman
    The price of the unit and power source aren't all that's required. You could get by making small batches, But to really crank out enough to heat your house and maybe some friends. You'd also need several other things like a good drier or ample storage on racks to dry them. Then there's the storage. And if the fiber is too large/coarse. You'll need a hammer mill. The list goes on.
    It would be fun to play with, But not all that as you'd be a slave to making your heat. Lots of work-prep need's to go into the dust. It sounds easy, But you'll need to keep an eye on moisture content.
    savemoney likes this.
  7. Lousyweather
    Lousyweather
    ugh...not THIS again......:hair:
    imacman and jtakeman like this.
  8. jtakeman
    Hey, We could bring up the OAK debate if you'd like! ;)
    imacman likes this.
  9. savemoney
    Please don't, I get my share of that. Must have been the same when the Persians determined the earth was round!
  10. Woodporn
    Woodporn
    S. MA
    Anyone have a spark bucket I can borrow?
  11. eatonpcat
    The earth is round??? :eek: :loco: :crazy:
