Shortening up cycle time on a splitter.
Discussion in 'Chainsaws and Power Equipment' started by NY Woods, Feb 21, 2023.
  1. NY Woods
    NY Woods
    NY
    I have a Husky 22 ton and I seen guys doing some creative things with shortening up the throw/cycle distance with a lever that stops the travel of the wedge. I was wondering if anyone has tried putting a block of some sort on the stop end (1.5 inch steel part) that would shorten the travel distance instead. Would have to be fabbed from heavy steel of course and removable.
    Anyone try this route?
  2. The Wood Wolverine
  3. isaaccarlson
    isaaccarlson
    Colfax, WI
    You are better off making a small trip lever/arm that kicks the hydraulic control back to neutral. I have seen a few fabbed up that are adjustable. One guy used a string and that worked too.
  4. sirbuildalot
    sirbuildalot
    Mass
    If the goal is to have a faster splitter, I don't see how 1.5" less of travel distance will make any noticeable difference. Most hydraulic splitters can be stopped anywhere in the cycle. You could manually stop it 2", 6", 10" etc. before the end of the stroke if you wanted. Lots of people do this with easy splitting wood to save time. If you're referring to an auto cycle type of detent, I think I'd caution against it. Could void the warranty and cause potential injury.
    My recommendation would be to sell it and look for a faster machine. I personally recommend SuperSplit.
  5. In the Pines
    In the Pines
    I thought they made a donut or so for limiting the return and in my search looky what I found lol
    Splitter return stop block or other Ideas ?
    I like the switch idea, myself I stop the auto return when it is half way since I mostly split 16"
    If I was making money off it, sure the seconds add up thru a course of the day.
    Yet again if it was a true job, I wouldn't waste too much time on the residential splitters and invest into a faster commercial one asap.
  6. Screwloose
    If you are thinking about something placed as a spacer between the cylinder and the wedge/pusher you have to be sure that the attachment to the rod can withstand the stress of being pulled. Most are only engineered for compression.
  7. NY Woods
    NY Woods
    NY
    Had one. Took it off. It was just OK
  8. The Wood Wolverine
    I'm guessing he has a similar situation as me, when I split 16" for my parents. My splitter can take up to 25" and on the return stroke, it would be nice to auto stop the wedge at 18" so it doesn't fully detract. I'm usually caught picking up pieces and it goes all the way back. It would be a big time saver.
    T.Jeff Veal, Horkn and Screwloose like this.
  9. Warner
    I think T.Jeff Veal had a block he had on his splitter?
  10. Eggshooterist
    Eggshooterist
    Erff
    Barcroftb has a splitter that has an impressive cycle time....
  11. buzz-saw
    buzz-saw
    Ct.
    Yes this is something to keep in mind.
    Cylinder is really designed to push and not pull.
    I have seen where someone put a sleeve on the rod to limit travel on return stroke and it ripped the end of the rod and the nut off inside the cylinder.
    Not saying it won't work but some homework might be a good idea.
    T.Jeff Veal likes this.
  12. brenndatomu
    Not sure what the specs are on your splitter, but depending on what they are exactly, there are things that can be done to speed the cycle time up "the right way" without buying a new splitter. Many of those splitters have a 6.5 hp engine and a 11 GPM pump...with 6.5 HP you can swap out to a 13 GPM pump for about $135 or so, that gains you a little speed...and depending on the cylinder design, and size, you may be able to downsize the cylinder (bore size) a bit, that will gain speed, but you will lose a bit of power too...BUT, most people very rarely use the full capacity of their splitters anyways...most splitting is done well under 5 tons, 10 max (normally)
    Just throwing out some ideas...
  13. Barcroftb
    Barcroftb
    The Mitten
    Yea but probably not so helpful to just say buy a super split in this case. I’m with Dave upgrade your pump is probably one of the easiest ways to increase cycle time on a hydro.
  14. JRHAWK9
    JRHAWK9
    Wisconsin
    Probably one of the fastest hydraulics out there....
  15. FarmerJ
    FarmerJ
    Minnesota
    You can shorten the stroke so it only runs 18” if you only split 16” material. That 18” of rod you’re not cycling.
    rugged made splitter’s actually have two holes drilled into the beam for installing a block specifically for that purpose.
    you can also use stroke blocks. This is common in farming for adjusting digger depth on farm implements. So it’s not a new technique. This is the same idea behind a block on the beam.
    you will likely need to reset the return detention pressure so it’s not smacking so hard on the wedge. Rugged made made a design change to have a larger wedge bolt to attach the wedge to the rod for this reason.
    You can install a larger pump as suggested. Install a larger fluid return line to the tank etc. change out your fittings and such to the largest sizes in the valves/cylinder. Get rid of 90* fittings and go to either radiused or 22 1/2 or 45 degree fittings.
  16. isaaccarlson
    isaaccarlson
    Colfax, WI
    I don't know what to tell ya then, unless it was a crappy setup. They are the best way to limit stroke length because they are easily adjusted, reliable, and can be removed quickly. I might put one on mine for when I am working by myself.
    brenndatomu and Screwloose like this.
  17. T.Jeff Veal
  18. NY Woods
    NY Woods
    NY
    Looks like Elm.. but yes this is what I'm talking about, blocking out the splitter foot to reduce travel
  19. brenndatomu
    Well yeah...that would be the simplest solution, huh?!
    Sometime the most obvious things are right in front of you, and remain unseen! :picard:
  20. Warner
