Inner tubes on Kawasaki Mule?
Discussion in 'Chainsaws and Power Equipment' started by JD Guy, Feb 17, 2023.
  1. JD Guy
    JD Guy
    Upstate SC
    My recent new to me side by side has tires that have been previously plugged and leak down. The tire size is 23x11.00-10. I cannot find the correct tube size and wondering if 22x11.00-10 is “close enough”? The 23’s are showing out of stock everywhere I search online. The tire pressure is 10 psi front and 20 psi rear. Tread is still really good so don’t really want to shell out for new tires. My thoughts are should be just fine. Thanks!
  2. brenndatomu
    Yup, close enough...tires vary quite a bit from brand to brand/model to model anyways, sometimes more than just going down 1 size on the OD.
    Slime or a similar product works pretty well on those too...but you could do the tubes, in 'em, they can be a bit of a pain though too.
    Horkn, Barcroftb, JD Guy and 3 others like this.
  3. Barcroftb
    Barcroftb
    The Mitten
    I’d skip the tubes and use Multiseal. I’ve used the stuff for years and really like it.
    FAQs - Multi Seal
    Horkn, JimBear, JD Guy and 3 others like this.
  4. The Wood Wolverine
    X2, except on the slime. I've been slimed too many times changing tires to recommend the stuff.
  5. brenndatomu
    I've changed literally hundreds of tires with the stuff in them...only wore it a few times...must be some major difference in technique.
    You break the bead before the air pressure was out? That'll make a mess! :rofl: :lol:
  6. RCBS
    If I can't get it plugged, I take to tire shop for an inner patch. I've used slime in a pinch. Still have it in one front on the big tractor.
    JD Guy and brenndatomu like this.
  7. brenndatomu
    At the shop we had plugs made specifically for ATV tires...big and squishy with a mushroom head, put in with a special gun.
    Worked really well.
    Edit: Looked kinda like this...I think it was Tech brand?
    [​IMG][​IMG]
  8. brenndatomu
    I would agree that this is likely a much better product than the Slime brand. Most of these more commercial grade sealers have to be bought in quantity though...often 5 gallon and up. $$
    eatonpcat and RCBS like this.
  9. The Wood Wolverine
    It's not horrible if you know it's in there but when you don't, and your jamming away at the job,
    I've never tried breaking a bead under pressure. o_O
  10. RCBS
    I had to plug a front tire on my Mule MX when it was just two weeks old BTW. My kinda luck.
    eatonpcat, JD Guy and brenndatomu like this.
  11. brenndatomu
    Not fully inflated...just like pulling the valve core out and popping the bead before the majority of the pressure was out...
    eatonpcat and Jeffrey Svoboda like this.
  12. Barcroftb
    Barcroftb
    The Mitten
    It’s far superior to slime. I was at a farm and fleet back in the day and watched the owner of the company drive a railroad spike with an BFH into a tire and it sealed it. I bought my first gallon then and have been a customer since. It’s shelf stable. I’ve never had it go bad on me. They do sell by the gallon and I think they have smaller bottles too. The only drawback is you typically have to buy directly from them.
  13. JD Guy
    JD Guy
    Upstate SC
    All good suggestions and very much appreciated. I did consider taking the tires/wheels to my tire shop for inner patches and might still do that. Although I’ve never personally used the slime product I have heard that it’s a mess if you have to de-mount the tire at some future date. The other products maybe not so much? How do you get the product into the tire, through the stem after removing the valve core?
    Horkn likes this.
  14. The Wood Wolverine
    Yep, remove core insert goop.
    And let the tire guy know ya did before changing.
  15. brenndatomu
    Yeah...some of the better sealers will occasionally plug the valve stem and it takes a nail or something to poke it open...PITA, but its worth it in the end
    eatonpcat and Horkn like this.
  16. Horkn
    From what I read it's basically like slime. I love that stuff . At least for low speed off road tires especially
  17. Ikeholt
    Ikeholt
    indiana
    I've had great results using about half a can of evaporated milk. It seals weathered-cracked tires and punctures. Just squirt into tire thru valve stem with an old ketchup bottle. Cheaper than Slime and works better.
  18. Jeffrey Svoboda
    Jeffrey Svoboda
    Gotta love people and their quick fixes. :hair::headbang:
  19. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I’ve got a Kawasaki bayou 300 that has tires so weather checked you can see how much air is in them just by looking at them. Still have good tread. But they are always low or flat and I can’t bring myself to spend $400 on a new set. I may have to try this.
    So it really works huh???
  20. brenndatomu
    I've heard guys say this works pretty well...I have to think it smells worse than a gut wagon the next time the bead is broken down though! :faint:
