Does a Hydro Need to be Level When in Use?
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, Feb 16, 2023.
  1. isaaccarlson
    isaaccarlson
    Colfax, WI
    Who was it that asked about a bent hole?
  2. In the Pines
    In the Pines
    How tall is that? the picture makes it seem taller than it probably is.
  3. RCBS
    Can confirm my splitter has been operated at various angles at times. As others have said...the engine's oil is the limiting factor. Unsure on exact degree of tilt they will survive vs perish.
  4. lukem
    I'd be scared of snapping that off.
    brenndatomu likes this.
  5. chris
    if you are more than 10 degs or so off level find a better spot or shim things up more of a safety thing than anything else.
    buZZsaw BRAD, Horkn and brenndatomu like this.
  6. JRHAWK9
    JRHAWK9
    Wisconsin
    It's on the taller side. On my old splitter, I extended it maybe 4" or so and I was still getting fluid sloshing out when I dragged it back to the garage....due to the slope of the land I was driving on. I wanted to make sure I didn't have that issue on this one, so I went full send on the extension. :D
    nah, I am pretty careful of my stuff. I've got more important issues on hand if I snap that off.
    Horkn, brenndatomu and In the Pines like this.
