unprocessed logs
Discussion in 'The Wood Pile' started by farmer rob, Feb 15, 2023.
  1. farmer rob
    farmer rob
    Dundalk Ontario Canada
    I have a load of logs that I picked up last year and put them into my drive shed.I am wondering will they rot while in log form while undercover & dry? The reason I am asking is I do not have enough bins to cut split them all and would prefer not to have to double handle the splits.
  2. yooperdave
    I hope you stacked the logs on stringers? Getting them off the ground would help out. Then, being undercover, I wouldn't worry about them rotting; rather just being in the way.
  3. farmer rob
    farmer rob
    They are sitting on 2 power poles
  4. JiminyKicket
    JiminyKicket
    Seattle
    I think you meant “I would not worry…”
  5. yooperdave
    I stand corrected.....thank you sir!
  6. farmer steve
    farmer steve
    top of the hill york co. PA.
    Off the ground and under cover I wouldn't worry about them rotting.
  7. FarmerJ
    FarmerJ
    Minnesota
    That’s my thoughts
  8. Bill2
    Bill2
    New hampshire
    Yup-You're good
  9. Eric Wanderweg
    This past Labor Day I got a few mulberry logs that were sitting on the dirt floor of a woman’s barn for 10 years. Zero rot whatsoever and they were actually dry inside too. Your results may vary but as others have stated, you’re good to go.
  10. buZZsaw BRAD
    off the ground and undercover they should be okay for an extended period.
  11. FarmerJ
    FarmerJ
    Minnesota
    The fact they were in a barn out of the elements likely made the bigger difference.
  12. RGrant
    RGrant
    Connecticut
    To me, this whole notion is but a myth.
    Not an ounce of criticism for the position, just find myself to be a perpetual split mover.
    ... did everything I could to avoid saying I'm always touching my wood....
  13. Backwoods Savage
    I once cut some red oak logs that had laid on the ground in the woods for around 10 years. But I will admit about 10% was bad so I just left those in the woods. Sometimes wood will last longer than you think.
    Worry not.
  14. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    How big are the logs? Just curious. I am
    Picturing a 10 wheelers worth inside
  15. EODMSgt
    EODMSgt
    White Mountain Region, NH
    I agree with most that the logs should be okay however there are some variables to consider. What type of wood are the logs? What is your relative humidity? When you say 'under cover', does that mean completely covered by a tarp (or other outdoor-type cover) or are they inside a barn/garage-type structure? If they are completely covered with no airflow, even raised off the ground in a humid environment, a lot of species will still rot. I normally leave any logs I have waiting to be processed uncovered but supported off the ground and seldom have any issues.
  16. farmer rob
    farmer rob
    [QUOTE="Woodsnwoods, the pile is 6-8 feet tall and 16 feet long consisting of maple, ash 1 beech and 1 white oak log.
    It is approx 8 bush cord and totally in one of my Cover all buildings sitting on the 2 power poles
  17. Sourwood
    Sourwood
    Popcorn, IN
    Y e s, but the real trick is to touch wood a minimal number of times before getting intended use from it.
  18. farmer rob
    farmer rob
    [QUOTE="Sourwood, Yes mine goes from splitter into racks then into drive shed for 3-5 years and now with new house & Heatmaster Unit into my attached garage done with tractor and into the stove when needed.All handling after in the rack is done with tractor & pallet jack
    amateur cutter likes this.
