Sous Vide Thread
Discussion in 'The Smokehouse' started by BCB, Dec 28, 2019.
  1. Warner
    Cool, if your ever passing trough Bennington check out Henry’s!
    eatonpcat likes this.
  2. Skier76
    Skier76
    CT and SoVT
    Will do! Just checked out their website. Looks really good! Kinda reminds me of Singleton’s which is in Cavendish.
  3. Skier76
    Skier76
    CT and SoVT
    Radom tip:
    Sous Vide is a great way to reheat meat without drying it out.
    Chvymn99, eatonpcat, Eckie and 3 others like this.
  4. Skier76
    Skier76
    CT and SoVT
    Another delicious burger courtesy of my wife!
    eatonpcat, Chvymn99 and grandgourmand like this.
  5. Warner
    Was the burger cooked in the sous vide?
    eatonpcat and Chvymn99 like this.
  6. Skier76
    Skier76
    CT and SoVT
    Sure was! Then finished in a cast iron pan. And by finish, just about a minute a side to give it a bit of char.
  7. Warner
    Interesting.
    eatonpcat, Eckie and Chvymn99 like this.
  8. grandgourmand
    grandgourmand
    Ontario
    I haven’t done burgers yet. But it does a great job on sausages!
  9. Skier76
    Skier76
    CT and SoVT
    We’ve been cooking burgers like this ever since we bought the Sous Vide cooker. In fact, a burger is the first thing we cooked in it.
    In the winter, we finish in the cast iron; on the grill in the warmer months. But still will use cast iron depending on the weather outside.
    eatonpcat, Warner and Chvymn99 like this.
  10. Warner
    Cool, I’ll try it. We do steaks and finish in cast iron. Never thought of doing a burger that way. I’ll bet it turns out juicy!
    eatonpcat and Skier76 like this.
  11. Skier76
    Skier76
    CT and SoVT
    Absolutely! If you like burgers rare, it’s a really good way to cook them. Not that they turn out bad if you like them more done.
  12. Skier76
    Skier76
    CT and SoVT
    Burger from last night. I think this was 80% ground beef. Seasoned with salt and pepper.
    I like burgers on the rarer side. Came out awesome.
  13. eatonpcat
    Did it Moo when you bit into it?? Lol
  14. Skier76
    Skier76
    CT and SoVT
    HA! That sous vide gets it to the exact temp!
  15. Barcroftb
    Barcroftb
    The Mitten
    Looks perfect! What temp/time do you cook the burgers at?
    eatonpcat, Chvymn99 and Skier76 like this.
  16. Skier76
    Skier76
    CT and SoVT
    Thank you! 129F. My wife cooks it for at least an hour; if not a bit more. Then a hot, quick sear in cast iron.
    eatonpcat, Barcroftb and Chvymn99 like this.
  17. Barcroftb
    Barcroftb
    The Mitten
    Thanks! I’ve been using a crockpot and old brew controller for a poor man’s Sous vide set up. Been mainly doing steaks. So far I really like it. I never thought to do burgers. I see a dedicated Sous vide set up in my future. 907AC564-7814-45E7-86DE-52F35DEB8752.jpeg
  18. Eckie
    Eckie
    It probably kicked!
  19. Skier76
    Skier76
    CT and SoVT
    That’s a cool setup!
    The actual cookers are nice to have. Worth the investment IMHO.
    eatonpcat and Barcroftb like this.
  20. Barcroftb
    Barcroftb
    The Mitten
    Yeah I can definitely tell that a dedicated unit would be superior. The temperature drift on the controller/crockpot method is as much as 5 degrees and there is no water circulation. The water circulation isn’t a deal breaker since the crockpot has inherently consistent heat. The temperature drift is a product of the controller and isn’t desirable. It was a nice way for me to dip my toe into the method since I already had all the tools. I’ve still gotten fairly consistent results but a dedicated unit would be more convenient.
    Skier76 and eatonpcat like this.
