Chain cleaning
Discussion in 'Chainsaws and Power Equipment' started by Dougr6, Sep 4, 2014.
  1. Dougr6
    Dougr6
    Caney Ks.
    :confused:Can you direct me to a Thread or tell me what you guys use to clean your chains before and after grinding them? Any homemade recipe's that I can make at home? Thanks and have a great day.
    Stinny likes this.
  2. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
  3. Shawn Curry
    Shawn Curry
    Western NY
    Floss with oak :saw::D
    splitoak, macpolski, Dougr6 and 2 others like this.
  4. Stinny
    SquareFile likes this.
  5. Stinny
    Pallet Pete does a lot of chain sharpening. He cleans them before he gets to work on em'.
    Dougr6 likes this.
  6. Grizzly Adam
    Grizzly Adam Guest
    If I recall, Pete uses a green degreaser before and we-40 after. I use a degreaser as well and use bar and chain oil afterwards.
    Kg461 and Dougr6 like this.
  7. Shawn Curry
    Shawn Curry
    Western NY
    Any buildup or burning on the chain is a sure sign that it either needs more oil, or needs to be sharpened. I don't bother cleaning them before sharpening, other than blowing it off with the compressor. Pour a little bar oil on them before returning them to their packaging, and my saw case. They clean right up when you start using them again.
    macpolski and Dougr6 like this.
  8. cutforfun
    cutforfun
    Purple power/super clean works great. Spray it on and then hit it with a big stub brush then rinse. Blow it of and put it to work or spray some wd40 so it does not rust up.
    Dougr6 and PullinMyPoulan like this.
  9. Kg461
    Kg461
    Provencal, La.
    Industrial simple green/ nylon brush/ rinse. Crank and run to dry and relubes itself
  10. basod
    basod
    Mount Cheaha AL
    I like to leave them grimed up - lets me see the first tooth that I sharpened when it returns around the bar
  11. Carbine
    Carbine
    A few swipes with a small steel brush won't hurt anything. I personally don't see the need for anything further than that, but wd40 or silicone spray will de-gunk the pitch on them too.
  12. Dougr6
    Dougr6
    Caney Ks.
    Thanks for all the advice. I will try soaking then wire brushing the pitch and sap off of the one, then blowing it off with air so I don't start a blaze!:fire:
  13. thewoodlands
    thewoodlands
    I take the air compressor to them while they're on the saw, I also take a brush to the chain when they're on the saw, this will take a chit load off.
    Before they go on the grinder I'll wipe them down with a cloth, I do have a small container that holds some simple green I can soak the chains in before wiping them down with a cloth.
    This is the container I have the simple green in.
    http://shop.advanceautoparts.com/p/...mi/9015450-P?navigationPath=L1*14924|L2*15045
    HDRock and Dougr6 like this.
  14. clemsonfor
    Pallet pete said he uses simple green. I dont clean them but cutting g good green white oak makes im pretty shiny
    Shawn Curry and Stinny like this.
  15. Dougr6
    Dougr6
    Caney Ks.
    Went out today and finished bucking up and splitting 2 Burr Oaks before a thunderstorm moved thru.
    HDRock and Chvymn99 like this.
  16. Dougr6
    Dougr6
    Caney Ks.
  17. Shawn Curry
    Shawn Curry
    Western NY
    Chain should be nice and clean now eh? ;)
    Dougr6, clemsonfor and Stinny like this.
  18. Nixon
    Nixon
    West Sunbury,Pa .
    Air if the chain is reasonably clean just to remove excess oil ,etc .
    If the chain is really bad ,like when cutting in dirty wood , simple green followed by air .
  19. clemsonfor
    Curious.
    Why are y'all cleaning the chains anyway?
    I know pete does it cause lots part of his dealand it looks really professional to get a sharp clean chain back. But my chains are usually not that bad. Cutting wood tends to clean them and unless cutting really dry wood with a dull chain or really doady wood you almost never get much on them or at least i dont notice it??
    Just wondering is all.
  20. MasterMech
    Keeps the oil and gunk out of the grinding wheels.
