Tree of Heaven vs. the X27
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Jan 25, 2023.
  1. buZZsaw BRAD
    Actually it was the X25 as "five" doesnt rhyme with "Heaven". :emb:
    It was no contest.:axe:
    TOH splits so easily, i was even one handing it. Had half a PU load i hand split here. IMG_2501.JPG IMG_2502.JPG IMG_2500.JPG Wish elm split this easily!
  2. Sirchopsalot
    Sirchopsalot
    medium city in CT
    nice!
    I haven't grabbed any of that. But I would take a tree if I saw one for SS use.
    You get a bed load?
    Saw a lot of BL just outside of New Haven, mostly around municipal buildings and the like.
  3. buZZsaw BRAD
    Youre not missing much. I dont go out of my way for it, but need SS wood to mix with primo hardwoods for bundle inventory. If easy and primo straight ill take it. I left the gnarly chunks back at the score.
  4. Eric Wanderweg
    That’s some incredibly easy to split wood if you’re one-handing it. I kind of wish I took some a couple years ago at my “copped my fix downtown” BL/elm score, just to see firsthand what kind of firewood it makes.
  5. Mag Craft
    That sure has some straight grain to it. I wish elm would split that easy too. I have access to quite a bit of it around here and cannot pass it up.
  6. JB Sawman
    JB Sawman
    pennsylvania
    That wood is not very good drys to like paper and it seems to smolder rather than burn real well Kinda like sumac it does split easy the quick burner I like is sassafras JB
  7. buZZsaw BRAD
    Oh trust me there's MANY more SS woods id rather take but in my case hoarders cant be choosey. Problem with sass is i wanna mill it now. Worth a LOT more as boards than firewood.
  8. grandgourmand
    grandgourmand
    Ontario
    What ratio of sub-par wood do you put in your bundles?
  9. Biddleman
    Biddleman
    River Hills of Pennsylvania
    I have a boat load of TOH that Im going to kill the root structure than drop. Not sure how much I'll process. I have/ will burn it, but it seems to clog my CAT. You get exercise not just from processing TOH, but also from all the times getting up to reload the stove with it :rofl: :lol:
  10. grandgourmand
    grandgourmand
    Ontario
    I split it once and found it stunk. But hey for campfire wood it burned ok
  11. KSPlainsman
    KSPlainsman
    Kansas
    Man, that's looks like some very straight grain wood. Nice!
  12. buZZsaw BRAD
    Bundles have 6-7 splits. If the current rotation of dry wood has lots of primo btu wood thats heavy (sugar maple, black birch, oak) ill put 2-3 splits of SS wood. I dont grab at random and try to have an even mix. I have some cottonwood that was in the mix. Ill be sure only one split goes into them.
    If i had a choice of only one species for bundles it would be red maple. Dries in a year or less. Not heavy when dry either. Most common hardwood in Connecticut, but its pot luck where and when i score it.
  13. Dok440
    Dok440
    NorCal
    That looks like Holly-wood! You know, the stuff the leading man spits in the movies? All my firewood is crooked so this is just a dream.
  14. BuckeyeFootball
    BuckeyeFootball
    I cant stand them smell of TOH that being said in my expierence it burns decent id put it close to cherry.
  15. jo191145
    Burns pretty good for me. I have a suspicion, just a suspicion that the layer under the bark attracts and holds water very well. Just like tulip poplar. Someday I’ll try splitting the bark off. See what happens.
    It’s a heavier wood than I would have imagined. A log tote full is rather heavy. Not crazy heavy but more than I expected.
  16. JB Sawman
    JB Sawman
    pennsylvania
    Thats the problem when you get the sawmill !! causes problems between milling or firewood :rofl: :lol::wacky:
  17. Backwoods Savage
    It can!
  18. buZZsaw BRAD
    Ever mill any TOH? I imagine it would only be used for utility purposes.
  19. jo191145
    only use for TOH I’ve ever stumbled upon in writing is the Chinese used it a lot for cooking fires. Makes sense, fast burning, no coals. Heat up the Wok for a quick meal and move on :)
  20. JB Sawman
    JB Sawman
    pennsylvania
    I have not milled any yet but I would not rule it out some of the logs customers bring to be milled can be entertaining "Can you cut me 1x10 boards and the log only measured 9 inches :headbang::doh: rotten ant infested ,and crooked so a ailanthus covered with lanternfly poop could be a possibility would be crappy boards:DJB
