Mystery Solved
Discussion in 'The DIY Room' started by ReelFaster, Jan 23, 2023.
  1. ReelFaster
    ReelFaster
    S.Jersey
    We've been at this house coming up on 7yrs, my daughters bedroom has notoriously been very cold. It is however over the garage so we somewhat expected that. Her room also faces the front of the house, W - NW where prevailing winds usually come.
    From time to time we've noticed some surface mold on the baseboard near the corners, only on the baseboards along the wall facing the front of the house and usually always in the winter. We noticed again recently when she had a blanket shoved in one corner and bean bag in the other laying on the baseboards, it created some condensation and the mold.
    We are about to redo her bedroom and replace the rugs with different flooring. First thing I wanted to do was pull those baseboards and see if there was any additional mold or damage, and there was absolutely nothing (Phew).
    While removing the baseboard I put a small hole in the drywall. I immediately felt air gushing in. I stuck my fingers in more and made the hole bigger so I could feel around and see if there was any darn insulation, which there was. With the hole now being the size of a golf ball air was just blasting in, I knew something wasn't right. I was about to tear down the entire wall to see what the hec was going on. I shared the info with my bro in law and he suggested pulling the soffit on the small roof just outside of her bedroom. I did and low and behold there was nothing on the outside of her wall in that soffit cavity. It's her drywall, insulation and then nothing :headbang: nothing at all no sheathing on the outside in that soffit cavity, the air is just going up in the vented soffit and just hitting the bottom 2-3ft of her wall.
    I was stunned, couldn't believe it. Now where the siding begins there is the vinyl siding, foam board insulation, sheathing, insulation then drywall. Instead of air sealing, insulating, and notching foam board panels or plywood to seal up I am thinking of using a fast coat spray foam.
    I am sure room will always be a bit chillier being over the garage, but I think this will help for sure.
    20230121_150704.jpg 20230121_150714.jpg 20230121_153308.jpg 20230121_155428.jpg
  2. yooperdave
    Are you using closed cell foam insulation on those stud spaces? Are you going to install a couple small louvre vents in the walls (triangle area) of the space over the porch roof?
    Is there a scuttle or some form of access to this area?
    something like that would drive me nuts!
  3. Canadian border VT
    Rooms over garages are notorious for being insulated incorrectly.
    watch a few you tube videos on how to do it correctly
    If those studs cross through the insulation envelope.
    Wood has low R values if not vented properly, wood gets condensation where hot meets cold, like your bathroom mirror in shower
    then they rot in that little roof area
    not surprised you didn’t have mold with that amount of air flow
    probably condensation that fell to base boards
  4. bogieb
    That is how my hole house was (well, I don't know about the kitchen since I haven't torn it apart, but I have no reason to doubt that it is the same way). I was like WTF when I went to replace a portion of drywall and was looking into my attic when I took out the 1" insulation. Sucked custom cutting plywood for each of the holes.
  5. ReelFaster
    ReelFaster
    S.Jersey
    For the spray foam I was looking at this product.
    Fastcoat Insulation Spray Foam
    I can access this area by removing the soffit panels shown in the picture, that's how I got in to take the pics and see what was going on.
    Didn't plan on adding any vents but that's not a bad idea.
    theburtman, bogieb and yooperdave like this.
  6. ReelFaster
    ReelFaster
    S.Jersey
    I'd like to rip the drywall down in the garage and really do it right to make her room more comfortable. But time and money eludes me these days!! Hoping this make a bit of a difference.
    theburtman and bogieb like this.
  7. ReelFaster
    ReelFaster
    S.Jersey
    Exactly, I am dreading having to do that plywood notching I am not the best at it so I guess I am taking the easier (and more $$ way) way out using the foam. I can remove those soffit panels and hit that area really well and really seal that up.
    Still stunned it was built like that. These home were built solid, back in the late 50's early 60's but this really threw me. Not sure why they couldn't have run the sheathing all the way down.
  8. billb3
    The overhang on raised ranches can be the same way. Pretty much worthless bit of insulation if there is any and nothing to stop the wind.
    If it was coming in, it was also going out somewhere else.
  9. ReelFaster
    ReelFaster
    S.Jersey
    So true, I am just sort of relieved I found this. I know it's not the silver bullet answer to correcting the rooms cold issue being over the garage but I can't not help think this will help a bit blocking that cold air just gushing in and slamming against the front wall with basically nothing blocking it but some old insulation.
  10. brenndatomu
    I think I would do the ole "cut n cobble" on that...you get a sheet of rigid foam insulation of the appropriate thickness and cut it to fit in the hole(s) but you dont have to be very accurate, because, you will then take spray foam around the edge to seal it in place...works great for basement sill plates too (a common air leak area) I've done my sill plate, and some work in the attic this way...works great!
    Here is a pic of the idea...and a link to more info. Cut-and-Cobble Insulation - GreenBuildingAdvisor (I cut my foam a lot closer to "custom fit" than they did in this pic...mine is more like 1/4" ish the whole way around)
  11. yooperdave
    Done once and done right! Takes a bit of time but so what?
