Bar Oil Puddling
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, Jan 19, 2023.
  1. buZZsaw BRAD
    This was mentioned in a recent thread and this question popped into my mind. If the oiler is turned all the way up (on saws with this feature) will this cause the saw to leak bar oil in storage?
    gwoods71, JB Sawman, MikeInMa and 2 others like this.
  2. In the Pines
    In the Pines
    it's not supposed to from my understanding. A husq will dribble though if you look at it wrong.
  3. buZZsaw BRAD
    Some of my Stihls do it. Havent really observed which ones and if the oiler is turned all the way up or not.
  4. FarmerJ
    FarmerJ
    Minnesota
    Haven’t touched the oiler. Shoot, I haven’t even put a gallon of gas through it yet.
    it’s already leaving spots on the floor.
  5. In the Pines
    In the Pines
    I don't think my stihl can be adjusted and I haven't used it in so long I don't recall if it ever did.
    My husqs are not that bad, they really don't dribble but I leave a rag under them anyway.
    corncob, clemsonfor and JB Sawman like this.
  6. Jeffrey Svoboda
    Jeffrey Svoboda
    I've found where the adjuster screw is the source of a leak sometimes.
    Other times the tank vent doesn't vent. Once you run the saw and get everything good and hot, pressure builds inside the oil tank. Once you shut it off and it cools, there's still pressure inside the tank pushing bar oil out?
    If that's true though the pump should create a vacuum inside the tank and then bar oil shouldn't leak??
    Just thinking out loud here. :loco: :crazy:
  7. JB Sawman
    JB Sawman
    pennsylvania
    From time to time all saws seem to leak bar oil some just a spot I have seen some need a diaper a lot of the homeowner saws with the plastic oil pumps seem to be the worst (They are the ones that come in the shop in the plastic cases with the lake of bar oil in the bottom ) it seems some models are more prone to leaking than others within a brand but I do not think one brand of saw is any worse than the other except the cheap poulans they seem to be the worst JB
    gwoods71, Horkn, Mag Craft and 3 others like this.
  8. clemsonfor
    Not any more than an adjustable oiler set all the way down low !
    But what it will do is cause the saw to possibly drip more after it's run and just set down just due to more oil being slung into the clutch cover and running down the bar sometimes as well.
  9. buZZsaw BRAD
    Rain day here so tinkered with saws. 500i had an "accident" :picard: :rofl: :lol: IMG_2439.JPG
  10. Eggshooterist
    Eggshooterist
    Erff
    Like a little puppy.....
  11. Eggshooterist
    Eggshooterist
    Erff
    All my saws will leave a puddle of residual bar oil from it naturally flowing off the saw but once it stops that they are done. I've had saws in the past that were pulse driven and they pressurized the oil tank. I had to crack the cap to relieve any pressure and leave it cracked while setting. Temperature fluctuations would cause more leaking.
    Maybe these would help the leakers....
    They make them for Husqvarna too...
    :D:rofl: :lol:
  12. buZZsaw BRAD
    :rofl: :lol: What about Echo?:whistle:
  13. Eggshooterist
    Eggshooterist
    Erff
    Echo is like Dodge in a Ford / Chevy fan boy argument. They don't even enter the picture.
  14. buZZsaw BRAD
    What size would fit the 500i?
    JB Sawman, Horkn and Eggshooterist like this.
  15. Eggshooterist
    Eggshooterist
    Erff
    Not sure but it would be funny as heck to see a guy at a GTG with a diaper on a saw.
  16. buZZsaw BRAD
    Mebbe this guy was wearing one :rofl: :lol:
    Can you believe the cojones?
  17. Mag Craft
    Chainsaws leaking bar oil are a fact of life and I do not even worry about it anymore. I put a piece of cardboard under them.
  18. clemsonfor
    Except they don't fall apart and electronics don't intermittently work :rofl: :lol::rofl: :lol:
  19. buZZsaw BRAD
    Any observations based on adjustable oilers Roger?
    JB Sawman and Horkn like this.
  20. Eggshooterist
    Eggshooterist
    Erff
    There is definitely that lol. I've owned several vehicles from all the big three. Cars and trucks. All my saying.
    JB Sawman and buZZsaw BRAD like this.
