What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. Scotty Overkill
    I've gotten decent at repairing these old plastics. Best filler I've found is the factory material.
    Going to try and fix the old tank that came with this saw and if it works out will probably pass it on to someone who needs it. It has a crack that someone epoxied over. Someday when I have time I'll dig the epoxy off and weld it up.
    Eggshooterist likes this.
  2. Scotty Overkill
    I'm building a custom muffler from scratch. I have the original muffler but being how HTF they are, I wanna leave it stock and just build a tri-port of my own design, with interna flow channels. I've made up the patterns, just gotta plasma cut them out in my shop and form/weld it together. I'll post it up when I do the work.
    Also going to make several custom bucking spikes for various builds.
    Chud, The Wood Wolverine and Lehman like this.
  3. Scotty Overkill
    I was just gonna build a "whatever" saw out of this one, being how hard parts are to find, but I started gathering up some nice parts so it led to more than I had originally hoped for. I may even send it to Glock37 for powder coating down the road.
    Chud and Lehman like this.
  4. The Wood Wolverine
    Dang! He drinks that hi-test koolade. :drunk: Are you in his will? :vulture:
    Jeffrey Svoboda and Chud like this.
  5. Lehman
    Lehman
    Minnesota
    Not that it isn’t a high price but he may get it or close for a collection, haven’t made a new one in years and they were all production saws for the most part and rode hard .
  6. The Wood Wolverine
    Stihl 084 Av Chainsaw | eBay
  7. Scotty Overkill
  8. Latitude59
    Latitude59
    Alaska
    Not sure yet. Has the manual valve but may have been switched out. But has the oem rubber nipple and clip over pulse hole so probably original. Didn't realize they had deleted the auto decomp later. Most people did it anyway because of leaks.
    M2theB and The Wood Wolverine like this.
  9. corncob
    corncob
    Somewhere in Lower Michigan
    My new Echo. I need to dremel the muff yet.
    M2theB and SKEETER McCLUSKEY like this.
  10. Chud
    Chud
    Nope but I asked. Apparently the son in law is going to inherit the hoard. His boy is not interested. :loco: :crazy:
    Mint, maybe never gassed 371, 272, 288, 268, 258?, all the stihls, buried huskies I can’t get to to look at. How could someone not be interested. At eBay prices it’s worth millions.
    What’s the big Dolmar? He’s got a new one.
    084 new. They are all on the top shelf where they can’t be touched and covered with blankets.
  11. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  12. Latitude59
    Latitude59
    Alaska
    Per the numbers its a 2001with manual decomp valve. Cleaning up nicely. A4AC7C6D-7CDD-4E81-83C7-1DCA51FE43EB.jpeg FCECCA7E-55EA-4097-B412-C3DF83A702CB.jpeg
  13. Lehman
    Lehman
    Minnesota
    I just got an 024 super to fix for a guy because he had a couple kids from the local forestry class come to help cut some dead balsam and even though they claimed they knew how to run a saw they didn’t apparently. They started them to warm them up and he didn’t take it off high idle with the brake on and now it won’t run. He called me up saying my wife’s pizzed because I let a kid use her old saw that her dad bought her and now it won’t run so that’s what’s next. I’ll snap a pic or two it’s really nice, told him if the cylinder is bad it may end up and 026 because I don’t think I have any super cylinders and refuse to use aftermarket.
  14. Lehman
    Lehman
    Minnesota
    44B8562B-089B-4F43-9A27-EC0A9A8F03CF.jpeg 2602F832-E883-469F-B383-927FBBC21006.jpeg 8EE70FFA-F0AA-401A-AA91-044B71B25682.jpeg F0B6F6F0-EA17-404D-A119-0648D58130D8.jpeg
    already have it running again, going to pressure and vac test seals but they look like they’ve been changed already. It will need a new drum bearing a good used clutch drum and clutch, the melted cover getting replaced . Then I’ll give it a good muffler mod and advance the timing a touch. Pressure and vac test and send home.
  15. Eggshooterist
    Eggshooterist
    Erff
    I like those little saws.
    Chud likes this.
  16. Eggshooterist
    Eggshooterist
    Erff
    I have some top secret stuff on my bench...
    Scotty Overkill and Chud like this.
  17. Eggshooterist
    Eggshooterist
    Erff
    #proprietary :rofl: :lol:
    Still a bunch of polishing ect to do.
    IMG_20230121_152811039~2.jpg IMG_20230121_151603467~2.jpg IMG_20230121_152039684~2.jpg IMG_20230121_152036218~2.jpg IMG_20230121_151639923~2.jpg
    M2theB, Skier76, J. Dirt and 3 others like this.
  18. corncob
    corncob
    Had the 090 on the bench today (minus the bar because the bench isn't long enough) Quite a saw. I need to dress the square tooth chipper chain when I get time.
  19. Scotty Overkill
    Welp, looks like I'm building another 200T! Just picked this one up this evening, it took a ride out of a tree.....
    Also picked up a Husky 435 parts saw for 25 bucks off the same seller....
    I got a problem....lmao....
  20. Eggshooterist
    Eggshooterist
    Erff
    It's a good problem.
    J. Dirt, Scotty Overkill and Chud like this.
