Splitter valve
Discussion in 'Chainsaws and Power Equipment' started by T.Jeff Veal, May 28, 2019.
  1. T.Jeff Veal
    We bought a County Line 30 ton fast cycle splitter bon Sept '18. A few days ago the valve started feeling sloppy while running it. Sometimes on the return stroke, won't pop lever back to neutral, forward stroke lever feels sloppy and wouldn't stop when released, wedge would slow down,but continue to advance. I noticed a cap on top of the valve with screw and lock nut on it. Does it need adjustment or take it back to TSC, it is still under warranty.
  2. TurboDiesel
    ^^^this^^^
    :handshake:
  3. Bret Hart
    Bret Hart
    Central NY
  4. T.Jeff Veal
    Thanks brother. Haven't heard from ya in awhile. Hope you have a blessed day
  5. TurboDiesel
    Been on the run lately.
    Thanks:handshake:
  6. triptester
    triptester
    S.E.Wisc.
    Take it back if under warranty. I had a similar problem it was a broken stud at the back of the spool.
  7. Kram
    Kram
    Hey T. Jeff Veal, how did you make out with that valve issue? I have a County Line 25 ton splitter and the valve is sloppy just as you described yours above.
    It won't always close on retract and isn't crisp between neutral and forward lever positions.
    Is there an adjustment or a user replaceable part inside the valve that can solve this problem? Thanks for any help from other Hoarders.
    T.Jeff Veal and stuckinthemuck like this.
  8. stuckinthemuck
    stuckinthemuck
    Put an “@“ before his name to notify him. T.Jeff Veal
    T.Jeff Veal likes this.
  9. Kram
    Kram
    Thanks. Do I do that right in the message field here?
  10. stuckinthemuck
    stuckinthemuck
    Yes. For Jeff start with the @ and type his name with the period and no space. It’ll give you a selection of members to choose from or the individual’s name you typed.
    MikeInMa, theburtman and T.Jeff Veal like this.
