I made pallet kindling today.
Discussion in 'The Wood Pile' started by ThomH123, Jan 15, 2023.
  1. ThomH123
    ThomH123
    East Granby
    I find it easy to make kindling from pallets. I use my circular saw and if needed my power miter . Nice oak and maple wood.
    0FEDEFAD-CD4C-433C-92DA-AF2A43D46D11.jpeg CE9A0C17-286D-4C3E-95B7-45D5218C3C7F.jpeg 18C562A6-D529-4306-87DD-2388FBFAE5E5.jpeg 3CE3FFE4-36D1-4C8C-AFAC-A1339A3FD3BD.jpeg 9154D2B8-B15A-43BB-AB04-1DFA702F1756.jpeg 745D60C4-6511-4190-9ED1-A9DDF67A5F37.jpeg 887273FA-0B98-4DCE-8996-6FE2AE2476F4.jpeg
  2. MikeInMa
    Nothing wrong with that kindling!
  3. brenndatomu
    I chopped up some elcheapo softwood pallets for kindlin and its the best...lights so easily and burns clean n hot quickly.
    :thumbs:
  4. KSPlainsman
    KSPlainsman
    Kansas
    I do the same thing. I even have a couple businesses that ask me to take their pallets, because they get so many. I use it for kindling and on days where I just need to take the chill off in the garage.
  5. buzz-saw
    buzz-saw
    Ct.
    Pallets for my kindling. I get them from work and run them through their bandsaw and put in boxes all I have to do is bring them home. When the box gets empty I just repeat the process.
    Great fire starting wood for sure and free makes it even better.
  6. figor
    figor
    Usa
    I tore out the kitchen pine subfloor in my 110 yo house and made kindling out of it about 3 years ago. Man that stuff would light a fire fast.
  7. Skier76
    Skier76
    CT and SoVT
    I just started doing this and they work great. I use my kindling cracker on the a few of the wider planks to give even small splits. Great way to reclaim pallets that are no longer good for stacking.
  8. 203coffeeman
    203coffeeman
    Connecticut
    Bought a kindling cracker couple years ago. What a GameChanger for starting fires. Great for my pizza oven too.
  9. coreboy83
    coreboy83
    NW of Twin-Cities
    Awesome stuff. I always do it on the clock.
  10. brenndatomu
    Hey, somebody is gonna hafta clean up the mess anyways, right?! :whistle: :thumbs:
  11. In the Pines
    In the Pines
    I just scrounge the chunks and slivers that fall off from splitting. last cycle of splitting gave me over a 27 gallon tote of kindling.
    Sometimes I bring home the hardwood scraps when I fix pallets at work. I can sell scrap pallets for 4 bucks a piece so they all get sold.
    Good pallets are going for 6 a piece.
  12. brenndatomu
    Surprised junk pallets bring that much...
  13. In the Pines
    In the Pines
    inflation and shortages - they were only $2 for years. Not really worth it.
  14. buZZsaw BRAD
    Nice stuff there Thom. :thumbs:
    Ive done that plenty of times over the years. I get nice clean ones from suppliers. I cherry pick. Sometimes torn between using for stacks or firewood.
    Id kill all the batteries on my cordless circular saw cutting them up.
    Skier76, ThomH123 and Chazsbetterhalf like this.
  15. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    I want one that mounts on the wall and you pull down on the handle. But man, not 200 bucks of want!
    Current system of hatchet in the bench vise sharp side up and hammering boards on has been working.
    Wall Mount Steel Firewood Splitter, Kindling Wood Cracker Cutting Tool for Home?Not Easy to Deform and Rust – Vrshrub
    ThomH123 and brenndatomu like this.
  16. Yawner
    Yawner
    Louisiana
    I have not seen one like that. Very cool. Sure seems overpriced, though. Heck, seems you could have a fabricator make one for that. But I've never hired one, so, that may be a pipe dream.
  17. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Geez....I have a buncha that from cutting pallets in half. The pieces are outdoor seasoned, but have nails in them. I was going to toss them in my burn barrel, but if you're interested in them, we could arrainge a short gtg. I'm maybe an hour from you (if that).
    Sca
    Skier76 and buZZsaw BRAD like this.
  18. Lennyzx11
    Lennyzx11
    So today, I had to make some kindling and had some time. And beer.
    So here’s my version 1 of a kindling splitter.
    I bought a 48” piece of 2x2”x1/4” angle iron and a Fiskars machete. Since it has a “lifetime guarantee “ wink wink.
    First I cut the 48” angle iron into 16” pieces. I planned using it all but that wasn’t necessary I found.
    Then I drilled 6 holes in the angle iron. 3 in each. Two for mounting and one for the pivot. I used a 3/8” drill bit because that was what size the hole in the machete blade was.
    Though I have a bandsaw, welder, shop tools, I wanted to make this easy to do if possible with ordinary tools most guys have.
    So no welding involved.
    I cut the angles out with an angle grinder. (You can use a hacksaw but it sucks to be you then).
    Lag bolted it to a shop 4x4 and started testing.[​IMG]
    To my surprise, it worked really well! After cleaning up a pine pallet, I cut up an old oak one to test. Then there needed to be a couple more notches made. I used the angle grinder with the splitter mounted. Looked at a “good” angle with a test piece of kindling and then made the steps a 90 degree angle to keep things simple.
    Easy 2 beer project. Split two 5 gallon cans of 12” x 1” pine and oak in roughly 15 minutes. Like an old time paper cutter.
    The machete is held by a 3/8” bolt and self locking nut. It can be removed to go murder zombies if needed or replaced with the lifetime guarantee as no changes were made.
    I didn’t even sharpen it more.
    Though it works fine, the 4x4 mounting is a bit thin for me at the sides.
    I’d rather see the contraption on a 6” piece rather than 4. I was thinking using a 2x6 as a base and then mounting that to whatever post, wall, etc. on second thought, drilling the mounting holes closer to the centerline would work to leave plenty of “meat on the sides of a 4x4.
    The factory holes in the blade for the pivot made the blade and end set past the back of the 2x2 angle when swinging over center. To make it work properly, either redrilling the hole in the blade(voiding the guarantee) or using larger angle iron to set it “out” a bit more would be the right thing to do or trimming the blade down around the pivot point(again voiding the warranty).
    Or do as I did and circular saw a kerf in the mounting board so it has clearance to swing.
    As I said. Fun project. And those thin pine pallets that nobody like using are perfect for kindling.
    Lenny
  19. Eric VW
    Great project and write-up Lennyzx11 :handshake:
    ThomH123 likes this.
  20. Skier76
    Skier76
    CT and SoVT
    Great work Lenny! That’s a really nice setup! Thanks for sharing with us.
