Heatmaster G4000 Install
Discussion in 'OWB's and Gasification Boilers' started by morningwood, Nov 24, 2022.
  1. Farmchuck
    Farmchuck
    Nepa
    Sounds like the creosote in the corners is a common thing based on you & Lukem. I will have to check the filters out on Supply house. What did you set your dampers to vs the factory settings? Thanks Morningwood!
    brenndatomu likes this.
  2. Farmchuck
    Farmchuck
    Nepa
    Hey Lyle you have a good memory! Hope you’re doing well up in Vermont.:)I guess I’ve been called worse than interesting!:DPerhaps I will have to start my own thread I don’t want to derail Morningwoods thread I just figured they were both the same brand stove & we could compare thoughts.
  3. Farmchuck
    Farmchuck
    Nepa
    What it looked like @ 7:15am this morning: B73D1EB8-3D4D-4312-AE9F-0149D0A2E4E4.jpeg
    morningwood likes this.
  4. Farmchuck
    Farmchuck
    Nepa
    What I added this morning: 1D7D03BC-3458-4678-AABA-034255103A3E.jpeg C799062D-1D99-4171-95C9-9BAA8DDE4B56.jpeg 1D7D03BC-3458-4678-AABA-034255103A3E.jpeg FEC231F3-B258-4DDE-9CE1-9CE6BD42C440.jpeg
    morningwood and brenndatomu like this.
  5. Farmchuck
    Farmchuck
    Nepa
    What I had at 5:00 pm this evening: CE869B57-2578-42DF-9EF9-83E83C6E8D23.jpeg
  6. Farmchuck
    Farmchuck
    Nepa
    Water temperature was 165° at 5 o’clock
  7. brenndatomu
    Farmchuck likes this.
  8. Farmchuck
    Farmchuck
    Nepa
    60B65E60-D3A5-4526-B405-6531F9BB63D1.jpeg 0F010E30-0B58-4C64-A0F6-0C11B2640E37.jpeg What I added to hopefully get us through to the morning. Temperature is 28° outside.:
  9. Farmchuck
    Farmchuck
    Nepa
    Do these pieces look to big to you guys? D2448791-4ADB-40CF-94FD-BA3274EAD6A5.jpeg
  10. Farmchuck
    Farmchuck
    Nepa
    Maybe it’s hard to get a perspective on how big they are. But they’re not huge.
  11. brenndatomu
    Some of them are on the bigger side, but you have a nice mixture there, and nothing too huge, I'd say you're good, but I'll let someone that actually operates one on a daily basis decide...I guess bottom line is if its working well with that wood, run it!
  12. Canadian border VT
    I am happy wish rest of my body worked as well as my brain :handshake:
    Farmchuck and brenndatomu like this.
  13. lukem
  14. Farmchuck
    Farmchuck
    Nepa
    Which stove do you have Lukem? 4000? Do you happen to know the average moisture content of the wood you’re burning this year? Have you adjusted the damper settings like Morningwood gas? Thanks.
  15. morningwood
    morningwood Administrator
    Forget to answer your question about wood size. What I’ve heard a few dealers on Facebook say is if you can grab it with one hand then it’s a perfect sized. I’ve burned some stuff that was 6” around and it ate it without any issues. Size looks good to me based off of your pics.
    Based off of your pics it looks like you have it your load size dialed in already. After 12 hours you shouldn’t have any big unburnt pieces of wood left.
    My wood is around 20% moisture so I set the dampers to the setting for 15 - 25% hardwood that’s in the back of the manual. Some guys say it helps with wood consumption other say it doesn’t matter. IMHO I think it does some. From the factory it’s set at the high moisture setting ( more air ) and higher o2.
    The other pic I’ve attached is the idle setting. I changed mine to 55-5-30 because my fire was going out on warmer days.
    0BD5B234-9F2F-4942-B3FE-08C8C29DE519.jpeg 2105F0B2-004D-47E4-818E-B0209FE3BFF8.jpeg
  16. lukem
    I have a GS200. That's the older version of 4000. Wood is 3 years css... no idea on %. Factory damper setting.
  17. Farmchuck
    Farmchuck
    Nepa
    Thank you. I’m going to have to reread the back of my manual. I was so intent on getting the stove hooked up I just glanced over the back of the manual. I appreciate your input.
  18. Farmchuck
    Farmchuck
    Nepa
    Thanks Lukem.
  19. morningwood
    Figured I'd give an update to this thread of how things went the first year running the boiler.
    The only non-self induced problem was the low water limit switch going out. Luckily I was able to call my dealer and he walked me through jumping it. This was a known issue, so it really didn't come as a surprise. Called Heatmaster a few months ago to get a new one. They were suppose to email me, still waiting on the email, I need to follow up with them. Cleaning the boiler at the end of the year wasn't too bad. Next year, I will definitely pull all of the coals out and scrape the corners out when the boiler is hot. Made the mistake of not doing that, lots of time with a torch and putty knife. It was a miserable experience at best.
    By tote count I burned roughly 3.33 cords of wood, ninety-percent of the wood is dead ash. One tote was cotton wood, and one tote should of been dumped in the woods but I burned it anyways. Figured it was in the tote, might as well burn it. We did have a very warm winter so I'd suspect I'll probably burn around 4 cord a year. I'm heating my hot water to roughly 110° and the house stays around 71° or so. The boiler pretty much ran non-stop from November / December to mid-April sometime. We had a pretty cool spring, now if we can just get some rain.
  20. brenndatomu
    Yeah I think I heard your county is under some water restrictions? We are dry, but no restrictions yet, that I know of...
    morningwood and Farmchuck like this.
