DuraVent extended wall bracket
Discussion in 'Modern EPA Stoves and Fireplaces' started by Ernie G, Jan 14, 2023.
  1. Ernie G
    Ernie G
    Wyoming pa
    I'm installing a DuraVent brand chimney and I have to clear a 12" eve ..from the research I've been doing I need the extended wall bracket .
    I was wondering if anyone's used this and how it worked out ?
    I can't find anything about it on the web
    Thanks
  2. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    Ernie, I didn’t use that bracket but used a 45 degree elbow to offset the pipe on my shop.
    Edit… after looking at the picture I should have used it first from my through the wall
    Pipe at bottom and then straight shot up. I’ll have to try that when I clean it next time.
  3. Ernie G
    Ernie G
    Wyoming pa
    I was trying to avoid using any fitting or going through the eve ..I was hoping if this brackets worth the price it would be a straight shot up past the eve .
    Ernie
    brenndatomu and Backwoods Savage like this.
  4. Backwoods Savage
    Those fitting work very good.
    btw, welcome to the forum Ernie.
    brenndatomu and Ernie G like this.
  5. Ernie G
    Ernie G
    Wyoming pa
    Thank you for the reply and welcome!
    Ernie
  6. brenndatomu
    I'd also lean toward using a 22* or 45* fitting(s) over the extended bracket...the bracket means you have a longer run of horizontal pipe through the wall and that can cause draft issues and smoke rollout when loading...unless maybe you have a very tall chimney that will overcome the horizontal...but its always best to have as little flat runs as possible.
    Wait, now that I think about it, I don't think you can do what you want, you would have to have an extended support bracket too, and I don't think they make those, do they? That extended bracket you found is for the pipe after/above the 45*, and before going above the roof line...
  7. Ernie G
    Ernie G
    Wyoming pa
    I believe this bracket would be the extended bracket to support the T instead of the traditional mounting bracket that's close to the wall .
    Does the 45 make it harder to run the brush up the chimney to clean it ?
    I was thinking if I used the extended bracket to clear the eve it just have to use a 2' piece of pipe to get me from the T to the adapter inside the wall .
    Would a 2' horizontal run be to much ?
    Thanks
    Ernie
    brenndatomu likes this.
  8. brenndatomu
    You have to use a support bracket under the tee.
    A Sooteater will go right up through there with 45's no problem.
    As far as "too much" horizontal...depends on your chimney height, stove model, location, elevation, etc etc...it may be fine, or may not, hard to say for sure... more horizontal is never better though.
  9. Ernie G
    Ernie G
    Wyoming pa
  10. brenndatomu
    I'm sorry, you are correct...I've not seen that setup before.
    Doesn't look like overkill by any means...do you get much wind where you are?
    I personally would still use the standard bracket with a couple elbows...but that's just me and my 2 ¢.
    Ernie G likes this.
  11. Ernie G
    Ernie G
    Wyoming pa
    I do have some pretty good wind storms from time to time but I plan on also using a bracket where it passes by the eve which would be about half way from the T to top of the chimney .
    Thanks for the info !
    Ernie
  12. The Wood Wolverine
    I also vote for keeping the horizontal piece short and going up as far as possible close to the house. Use 2 45's to clear the eves. I did just this and sweeping is a non issue. I'll try and dig up a pic.
    Ernie G likes this.
  13. Ernie G
    Ernie G
    Wyoming pa
    After looking at the wall kit I have it's actually a Selkirk/ SuperVent brand .
    I've been looking for the 45"s and I can't find any ...searched all over the web .
    Where can I find these ?
    Ernie
  14. brenndatomu
    Selkirk/Supervent brand?
    They don't make 45's...they only have 15* and 30* kits...which 30* is what most people use anyways.
    Ernie G likes this.
  15. Ernie G
    Ernie G
    Wyoming pa
    Yes... SuperVent
    Looks like they do make 45's but it says they are ONLY for use in Canada.
    Im not sure the 30's are going to work for me ?
    Ernie
  16. brenndatomu
    Ernie G likes this.
