DHT Hydraulic Ram Leak
Discussion in 'Chainsaws and Power Equipment' started by Ohio, Jan 9, 2023.
  1. Ohio
    Not Ohio
    Noticed ram leaking after parking it in the barn. I've had the splitter almost 5 years probably 40 to 50 cord split with it. I cleaned it up but forgot to take pictures of it clean.
    DHT went out of business so no support from the manufacturer. I am not familiar with hydraulics. Fluid looks fine, not milky or anything also was at the correct level on the dipstick.
    Screwloose, Eric VW and Chvymn99 like this.
  2. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Some people are way more fussy than others…. But my DHT splitter has got a lot bigger mess than that going. I thought that was a cleaned picture. I’m not worried about mine yet, hasn’t leaked enough to tell about, as in I haven’t had to add any fluid yet. Not gonna worry about it until it becomes a pretty steady drip or tiny stream. Hydraulics leak! That’s just the nature of the beast. I wouldn’t worry about it especially if that is the before cleaning picture.
  3. Chud
    Chud
    Yeah I wouldn’t pull it until it becomes a small stream under pressure. Find a place that rebuilds cylinders in the meantime.
    Screwloose, Sandhillbilly and Ohio like this.
  4. donm1
    donm1
    NE Texas
    My DHT 22 ton splitter with a 4" by 1.75" cylinder developed a slight weep this fall. After looking around, it appears that DHT, Country Line, Husky and Speedco splitters may use the same 4" cylinder. Found this YouTube video that gives a couple of links for the repair kit (about $60).
    Screwloose and Jeffrey Svoboda like this.
  5. Warner
    I wonder if the flat tires help with replacing the seals? :sherlock:
  6. corncob
    corncob
    Somewhere in Lower Michigan
    Any competent hydraulic shop can rebuild it. Seals are pretty generic.
    Ohio and Screwloose like this.
  7. Screwloose
    A little weeping is not much of a concern.
    If it starts dripping then any hydraulic shop can take care of it.
    brenndatomu and Ohio like this.
  8. Ohio
    Not Ohio
    In your opinion is this something that a first timer could replace the seals?
    Casper likes this.
  9. morningwood
    morningwood
    brenndatomu likes this.
  10. Casper
    Casper
    Cylinders are pretty easy. The gland removal can be tricky depending on the method the manufacturer used to secure it. If you're near Cleveland I can recommend a shop where you could take you gland and piston and they (Joe or his partner) can match up you o-rings and seals. Mine were under $20.00.
    morningwood, Ohio and brenndatomu like this.
