How would you go about it…?
Discussion in 'Chainsaws and Power Equipment' started by Sandhillbilly, Jan 6, 2023.
  1. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    How would you go about resolving this. It’s only been stuck for about a month, so that helps, right?
  2. The Wood Wolverine
  3. Chud
    Chud
    Reevaluate the situation in June :rofl: :lol:
  4. Sandhillbilly
    Sandhillbilly
    That would probably do the trick if’n you could get that rig to it in the swampy meadows ground.
    Even though the ground is frozen, it’s only froze 4-6” with a swamp underneath the crust.
  5. In the Pines
    In the Pines
    than this would probably be about the best time, come spring it sounds like it might disappear.
    I'd get another one of those, start digging the high end out and lots of board mats. No fun trying to chink away frozen mud from them tracks.
    No experience I've watched a guy on youtube pull these out, most were in swampy ground.
    Most importantly someone that knows what they are doing so you don't end up with 2 buried.
    edited to add a yotube link, maybe you can get hold of them if they are local enough.
  6. buzz-saw
    buzz-saw
    Ct.
    Plant some flowers around it and call it a day.
  7. brenndatomu
    Edit: if I get it out, can I have it? :whistle: :D
    Woof...that's a rough one...I think I'd bring in another machine to help dig out the high side a little, then use it to pull the stuck machine a little more upright before trying to start it...then between the two, use some timbers, mats, even some logs to provide a little support.
    I recall an episode of Swamp Loggers where Simitro (SP?) was able to dig his way out with the feller by grabbing logs and shoving into the mud all around him until he was able to climb/push up n out...impressive because he was in deep enough that they were concerned about water on/in the engine!
  8. JimBear
    JimBear
    Best bet is as others have said; another machine, some mats or logs. Mats would be preferable. Contact an oilfield supply company or crane/lift company to find some if you are unsure where to find them.
  9. FarmerJ
    FarmerJ
    Minnesota
    Lots of mats and and another machine.
  10. M2theB
    M2theB
    Central Massachusetts
    finish covering it!
  11. JimBear
    JimBear
    We will expect some recovery video or pictures.
  12. brenndatomu
    That might not look as bad once the snow is gone....might have slipped into a hole and then the snow drifted around it.... I'm sure the operator is still puckered up though!
  13. In the Pines
    In the Pines
    Definitely take video of it, the one I posted has over 21m views ! someone could pay for that recovery and buy a piece of new equipment if they get that many views.
  14. buZZsaw BRAD
    Can triple A winch it out???
  15. Sandhillbilly
    Sandhillbilly
    I got stuck clearing treesThe machine in the pictures at the start of this thread was loaded onto a grossly inadequate trailer and will be hauled out tomorrow to attempt to retrieve the smaller one. Only plan to get the 345 on site and unloaded tomorrow. The 345 will have to travel nearly a mile to the stuck machine from the only suitable place to get a truck and be able to unload.
    One of my biggest concerns is that the boss is not going to charge enough for this endeavor. There is already around 70 man hours in just the prep work and getting the 345 loaded up and into town.
    Screwloose, SimonHS, M2theB and 3 others like this.
  16. spotted owl
    spotted owl
    PNW
    Go old skool.
    Swamp mats and another machine. Dig it level, then dig and pull it out the way it went in.
    Owl
  17. Screwloose
    Maybe I'm missing something but.....
    If it's in just 4-6" of frozen ground and the rest is in swamp wouldn't it be safer long lining it with a few spaced out smaller machines?
    I'm picturing a large machine pulling hard breaking through.
    Sandhillbilly and brenndatomu like this.
  18. Sandhillbilly
    Sandhillbilly
    I had to be out of town so I didn’t get to see it, but they got it out. I guess the 345 excavator could budge and shake it but it was tipped over to far. So they used a wrecker anchored to an old deuce and a half 6x6 to get ahold of the boom to hold it up right, then was able to lift and pull with the 345. I wish I had been able to be there. Would have been some valuable experience
    Chvymn99, crzybowhntr, M2theB and 7 others like this.
  19. The Wood Wolverine
  20. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Glad they got it out.
    My first thought when I saw the picture was "was I the operator?" If so, I guess I would be looking for a job.:rofl: :lol:
