372 stalling out
Discussion in 'Chainsaws and Power Equipment' started by rotorburn, Jan 2, 2023.
  1. rotorburn
    rotorburn
    Jersistan
    C5CA5575-4D05-46A9-B00A-2DD9FA2B4617.jpeg Seeking the collective wisdom here for my low hour 372. It seemed a bit high strung so I turned out the high screw until it would four stroke out of the cut and max out at a safe 12800. Seems good, but now once warmed up and in between cuts when set down and idling, it will slow down and cut out. Should I turn the low screw in until it cleans up and call it good? Pic added because pics are good.
  2. Chud
    Chud
    That’s what I’d do. Turn the low in 1/4 and see if that keeps her running.
  3. clemsonfor
    It's flooding, lean the L screw out. But still has a crisp acceleration when you snap the throttle. Too much it will bog and slow to rev. You want that sweet spot between flooding out at idle and bog off idle.
  4. The Wood Wolverine
    I agree with the advice given above. :yes:
    Does it clean up in the cut pretty quick or does it take a while?
  5. clemsonfor
    I will also say there is a possibility that you might have to adjust the idle but I don't think you will. It will slightly pick up RPM on e your L needle is tuned right. But you might need to bump the idle down depending on if your L changes your idle speed. If anything you may have to bump the idle speed down a tad...but I think you may be fine
    Woodsnwoods and rotorburn like this.
  6. Mrxlh
    Mrxlh
    Dat Boot
    Make sure the intake boot flap isn’t rolled over. Donny Walker has been finding 1 out of 4 from the factory that way, causes a similar issue. His YouTube video shows in detail how to check/fix it…
  7. Hinerman
    Hinerman
    NE Oklahoma
    What makes you think it is flooding? Is it because he richened up the high side?
    Reason I ask, is because I have seen the cause of dying on idle to be either flooding, or the opposite, not enough fuel. I just have to try one way to see if it works, if not, I go the other way
  8. clemsonfor
    No. It makes me think that because if the L needle is too far out. If it starts fine will idle a little bit and even off idle be fine but if you set it down and 5-10 or more seconds later it cuts out . In my experience it's usually cause the L is set too rich or too far out and it causes the saw to load up and cut off.
    That's why I said what I said. I don't think it has anything to do with the H needle. If he turned it till it fourstrokes wide open out of cut and it also cleans up in wood that's properly tuned.
    Hinerman, MasterMech and Woodsnwoods like this.
  9. Mrxlh
    Mrxlh
    Dat Boot
    It’s an X-Torq, they tune funny being strato, mine has never idled correctly since new. I stumbled on to Donny’s video last week and as soon as I get to it, the carb is coming off to check the divider.
  10. FarmerJ
    FarmerJ
    Minnesota
    “Until it four strokes?
    what does that mean. Not a lot of 2-stroke experience here.
    MikeInMa and Woodsnwoods like this.
  11. clemsonfor
    When you rev the saw up (properly tuned one) it will be a clean rev sound and once it tops out in rpm it shouldn't sound clean or like it's missing or burpling as some people call it. Sounds like it's hitting every fourth stroke not every other stroke like normal. If it sounds clean and like it's reving to the moon when you pin the throttle wide open NOT in a cut it's way to lean and you will burn the saw up or score it. It should burple or "four stroke" and then when you put it in the cut and load it up it should clean up and just sound like a clean reving two stroke. It's something that's easier to hear than describe. I'm sure there some YouTube videos where the mic is just not obliterated by sound. I have a few saw videos but I doubt you can hear it in them as there just filmed with a phone.
    You can hear it by holding the throttle open and adjust the H screw in and out. If you turn it to lean it will rev to the moon lean, be careful and don't do it to much or long as it will score. If you go to rich it just will bog way down. The four stroking is in between those two.
  12. Mrxlh
    Mrxlh
    Dat Boot
    Only problem is on an X-Torq it has a limited coil, (unless he replaced it with a non limited) so it won’t rev to the moon. Hitting the rev limiter sounds close to 4 stroking, but not exact. On a limited coil it’s easier to tune the H with a tach.
  13. rotorburn
    rotorburn
    Jersistan
    Appreciate the responses. I’ve had saws ten years and never needed to touch the screws so it’s good to hear I’m on the right track. I would always rather be out cutting than in the garage tinkering, but when something is off, I need it resolved. There isn’t a small engine shop around here I would trust over the knowledge of this group!
    To answer a couple questions from above, it does clean up quickly in the cut or with a quick tap on the throttle, the trouble really shows up when I set the saw down to reposition some work and you can hear it blubber and drop revs. Also, saw is bone stock so that’s a good point about the coil limiting the potential for over revving. My adjustments up to this point have been done using a digital tachometer with idle set to 2700 and maxing out at just under 13000. 13600 rpm seems a little extreme for a saw I plan on having for at least 20 years.
  14. MasterMech
    Even then, the limiter will mess with the reading on most tachometers.
    On a limited saw, I like to set the H rich so it takes a lot of load for it to "clean-up" in the cut, and then make smaller progressive adjustments until it cleans up as soon as the chain starts to pull into the wood.
  15. saskwoodburner
    saskwoodburner
    Late to the game here, but that def sounds like it's loading up on idle (too rich on the L side). Just have to find the perfect middle ground between rich blob-blob-blob stall and lean bleem-bleem-bleem stall.:D
  16. MasterMech
    That "four-stroking" sound at wide-open throttle is tough to pick out (as a novice) unless you have someone to demonstrate it in front of you. Many make the mistake of confusing the rev limiter (on limited saws) sound for four-stroking, as it actually produces a similar effect, or the popping and blubbering of a H setting that is grossly over-rich. The best description I can give is the exhaust note goes from smooth scream to something somewhat "fuzzy" but still constant. You should not hear it "miss" as that is usually grossly over-rich.
    The symptoms you describe are classic for an overly rich L setting. Start with a perfectly clean air filter. At idle, adjust the L for peak RPM's, then adjust the LA for the desired idle speed. If you had to move it more than about 200 rpm, repeat this procedure. Then snap the throttle wide open and pay attention to how it accelerates off idle. If it bogs and then takes off, make small adjustments to the L screw (richer) until it accelerates smoothly, then reset your LA for the desired idle speed. Now adjust the H. If the H is grossly off to begin with, you may have to tweak the L side again after getting things in the ballpark. Don't be afraid of 13,600+ RPM unloaded. It's pretty common for saws in this category to flirt with and even exceed 14,000 rpm unloaded when tuned correctly. Remember, it will never see anything close to that speed when cutting and you aren't holding it wide open with no load for more than a second or two. It'll last longer and run cooler tuned correctly on 40:1 mix with a clean air filter than it will tuned extra rich "just to be safe". Keep an eye on your exhaust/muffler. If it's plugging the spark arrester screen then it's too rich, you're running the wrong type of oil (ashy or gooey), or way too much oil.
  17. clemsonfor
    If I remember right don't you have a video of this on YouTube? Basically a saw tuning video.
    Like he says the sound is kind of hard to describe and know exactly what your listening for without .much experience messing with two strokes. And like I said most videos on YouTube the sound is going to over power the mike and not let you hear anyway.
  18. The Wood Wolverine
    This is a decent one for audio quality.
  19. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Yes to the above responses with an emphasis on cleaning the air filter, filling with fresh fuel, warming up before adjustments, and keeping these saws below the recommended rpm. They can and will go fast, but their pistons are quite robust and benefit from conservative tuning in the long run. MasterMech’s vid is great except for the unlimited coil on this series (blue, sometimes stamped with rpm limit). Tachs go nuts when you’re over that spec.
    I tune like MasterMech except I use a tach to set the max below the rev limiter (13,000ish) and the tweak it while putting it in wood.
    M2theB, clemsonfor and Chud like this.
  20. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    It does sound like it’s loading up a bit. Start with a good air filter clean and the make slight adjustments to the L (in, clockwise) and see if that helps.
    clemsonfor likes this.
